Driving in heavy rain with Runflats
Old 05-12-2013, 01:17 PM
C6York
C6York's Avatar
Default Driving in heavy rain with Runflats
Yesterday ended up a white knuckle day while driving my 2012 C6...Runflats might be great for no spare but is it only them that have a serious issue in heavy rain?...I traded my 2010 Camaro for this baby and she never had the issues like I had yesterday?>
Did find out that I was between 33 and 34 psi cold...lowered them to 30 as door car suggests...any comments?
Old 05-12-2013, 01:27 PM
Flh Den
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
Support Corvetteforum!
Flh Den's Avatar
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
How many miles on the tires? Can you measure tread depth? What exactly happened to make it a white knuckle day? What model corvette? The stock Gy tires, if thats what they are, aren't bad in the rain if driven correctly, but a car with that kind of power has the potential to break loose even on dry roads if driven aggressively.
Old 05-12-2013, 01:30 PM
simplegto
simplegto's Avatar
St. Jude Donor '11-'12-'13-'14
No problems here. Don't forget you lost 800 pounds from the Camaro.
Old 05-12-2013, 02:10 PM
dvilin
dvilin's Avatar
Received 7,922 Likes on 4,808 Posts
No problems in the rain, perhaps it might be white knuckle driving in the snow, but rain, should have no problems even with bald tires.
Old 05-12-2013, 02:56 PM
RestoRoc89
RestoRoc89's Avatar
Heavy rain was a very scary experience when I first picked up my 2011 coupe (compared to my 2010 Camaro SS...). Hydroplaning all over the place. I very nearly threw away the brand new GY tires. I'm glad I didn't, because the root cause was the factory (mis)alignment. The car would track straight, but the toe was substantially out of spec. As soon as one tire lost grip going over a puddle, the other one would pull the car in a different direction. After a proper alignment, I find that the car remains rock solid in inclement weather.
Old 05-12-2013, 03:09 PM
rwillitt
rwillitt's Avatar
Lots of heavy rain in Florida, no problems with my 2007 coupe since I got rid of the GY's and switched to PS2 run flats. The GY's had about 15,000 miles on them and were terrible when it was wet.
Old 05-12-2013, 03:20 PM
bigswiss89
bigswiss89's Avatar
the GY's were awful in even the slightest wet conditions, but i've switched the michelins and they are sooo much better.
even the C7s are coming out with the michelin run flats now instead of the GYs
Old 05-12-2013, 03:58 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
When I had the OE Goodyear Supercar run flat tires on my Z06(wider tires than on your C6), they were scary in the rain, even at low speed. I now have the Bridgestone RE050A run flats and have driven them at 80 MPH in a pretty heavy rain, with mid '40's temp. No sign of hydroplaning.
I would say that mostC6 owners go with another tire when they need to replace the OE Goodyear's. On my C5, I went with the Michelin A/S run flats and they drove great at 75MPH in an extremely heavy rain storm with no hydroplaning.
Old 05-12-2013, 04:08 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,099 Likes on 810 Posts
Get different tires is the solution or do not drive in downpours
Old 05-12-2013, 04:13 PM
2vette2
2vette2's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
No problems here either. 2013 base coupe.
Old 05-12-2013, 05:31 PM
Torchsport
Torchsport's Avatar
St. Jude Donor '15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I've had a few pucker moments in my GS in downpours.
Old 05-12-2013, 05:36 PM
joec
joec's Avatar
Old 05-12-2013, 06:22 PM
Mad*Max
Mad*Max's Avatar
Received 1,499 Likes on 817 Posts
once you change the GY to Firestones you won't have any issues, even when the tread wears down
Old 05-12-2013, 06:57 PM
Old Boot
Old Boot's Avatar
Yes my 2012 GS likes to remind you to pay attention in deep standing water. just rain is OK but them puddles well ya ,wake up.
Old 05-12-2013, 07:05 PM
69L79
69L79's Avatar
Location: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
I have Invos on the GS. Way, way better than CrapYears in the rain. But, still no "picnic", for sure.
Old 05-12-2013, 07:12 PM
Red08
Red08's Avatar
Received 1,441 Likes on 780 Posts
I had a new set of run flats installed last month. On a drive back to Illinois from Texas two weeks later, I drove through rain 1/2 the way back. No problems at all.
Old 05-12-2013, 07:22 PM
Jim2003
Jim2003's Avatar
I had 52K on my 03 and no issues in rain. I got 25K out of the orginal GY and then switched to Michelins and it was better in the rain. The 2013 has not had the opportunity to be in real heavy rain just in showers, but it handles just fine.
To Driving in heavy rain with Runflats
Old 05-12-2013, 07:24 PM
RJRSW
RJRSW's Avatar
I have driven in a downpour in my vette at freeway speeds for over a 100 miles driving back from Vegas with Michelin AS ZP run flat tires with nearly 25k miles on them and they were rock solid and had no hydroplaning problem of any kind.
Old 05-12-2013, 08:49 PM
GrandSportRob
GrandSportRob's Avatar
MY GS is too new, only 700 miles & have yet to drive in heavy rain. MY old C5 had Goodyear eagle GS D3 tires & they were amazing in downpours, no issues at all.
Old 05-12-2013, 09:06 PM
psp6158
psp6158's Avatar
Why are you driving a Corvette in the rain? lol I didn't think they had windshield wipers... It was nasty around here... Glad you got home safe.
Quick Reply: Driving in heavy rain with Runflats
