Grand sportoil cap in a 13
Old 05-10-2013, 09:25 PM
skip89
skip89's Avatar
Default Grand sportoil cap in a 13
2013 with dry sump, how much oil and do they come with Mobil 1 or dexos
Old 05-10-2013, 09:29 PM
Stockcar Axeman
Stockcar Axeman's Avatar
Mobil1 from the factory and 10.5 qts.
Old 05-10-2013, 09:53 PM
skip89
skip89's Avatar
Default Thanks
I had a 2008 zo6 that always ran 160 degrees oil temp on the road. What do you find the newer dry sump GS cars run
Old 05-10-2013, 10:54 PM
GrayC5
GrayC5's Avatar
Oil capacity including filter for the 2013 GS dry sump engine is approximately 10.5 qts.
dexos™ is not a brand or type of oil. It is an engine oil specification developed by GM Powertrain engineers. Mobil 1 5w30 meets the dexos™ specification and is a licensed GM dexos1™ product:
licensed GM dexos1™ products
Also see the following links for additional info:
Welcome to the GM dexos™ Information Center
what you need to know about dexos™
NOTE: In addition to using engine oil that is approved to the dexos specification, one should also use the appropriate viscosity grade as specified in the owner's manual.
Old 05-10-2013, 11:10 PM
GrayC5
GrayC5's Avatar
Oil temps on our 2013 GS with dry sump run about the same (160 degrees) with ambient air temperature up to about 80 degrees. Our oil temps will run somewhat higher as ambient air temps rise above 80 degrees.
Old 05-11-2013, 05:55 AM
Don-Vette
Don-Vette's Avatar
Didn't you get an owners manual with that car?
To Grand sportoil cap in a 13
Quick Reply: Grand sportoil cap in a 13
