Chuck Cow Tune and Leaky Water Pump
Old 05-11-2013, 04:13 PM
Krazy_Legs
Krazy_Legs's Avatar
St. Jude Donor '13-'14-'15-'16
Default Chuck Cow Tune and Leaky Water Pump
Took the car to the dealership last fall for an oil change and checkup. I was informed that the water pump was sweating, nothing serious but it should be changed. OK., next spring, it is under warranty.
Put the original engine and transmission tune back in before I took it to the dealership, just in case. Turns out it was the thermostat, all fixed now, but they installed a new one, Ahhhh.
So, can I install Chuck's engine and transmission tune back in, or are the fans programmed so they will run all the time.
Can I just install the transmission tune and leave it for now.
Thanks.
Old 05-11-2013, 04:15 PM
0Chuck CoW
Former Vendor
Chuck CoW's Avatar
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Please call me....
Thanks.
Please call me and let me know what you're doing.
I'm here today.
Chuck CoW
Old 05-13-2013, 01:16 AM
Krazy_Legs
Krazy_Legs's Avatar
I'm here today.
Chuck CoW
So I phoned Saturday, and talked to someone who had no idea what I was talking about. Never heard about, /forums.corvetteforum.com. You were busy, and no return call.
The question was quite simple. The GM dealership took out the low
temp thermostat, fixed the leak, and put in a factory thermostat.
Now, can I install your engine tune back into the car, and the transmission tune ?
To Chuck Cow Tune and Leaky Water Pump
Quick Reply: Chuck Cow Tune and Leaky Water Pump
