Do you torque your oil pan bolt?
Old 05-02-2013, 01:19 PM
RobLo
Support Corvetteforum!
RobLo's Avatar
Originally Posted by c54u
http://www.c6registry.com/technical/manuals/2005OM.pdf
http://aoca.org/pdf/drain_plug_torque_2011.pdf
2005 owners manual states
5.5 quarts of oil - page 5-94
PF44 oil filter - page 6-13
18 lbs ft torque -first page of second link
I've been told on this forum that the Z51 model took 6 quarts of oil, it's not noted in the '05 manual but is noted in the '06 and up manual, same exact LS2 engine. I think it had to do with the oil cooler (extra capacity) on the Z51.....I use 6 qts. when I change mine and it's not overfull.
Old 05-02-2013, 01:29 PM
EVRose
EVRose's Avatar
I use 6 qts in my '05 even though there is no oil cooler. Extra 1/2 qt isn't gonna hurt anything.
Old 05-02-2013, 03:12 PM
01VETTECOP
01VETTECOP's Avatar
WOW, my 2006 Owners manual says exactlty what to use and how much to use of it.
Old 05-02-2013, 04:02 PM
Jimmy W1
Jimmy W1's Avatar
Originally Posted by GOLD72
Your statement is not quite correct. The PF44 standard filter was replaced by the PF46 standard filter. The UPF44 is still available as Delco's premium Gold Ultraguard filter. The UPF44 was not replaced by the PF46.
You are right, the PF46 did not replace the UPF44. It replaced the PF44. I called the dealer near here and he said the PF46 was the correct filter. That is what was on the car when I took it off. (The last oil change was by a dealer) That is what O'Reilleys said when I bought it. So, that is what I put on. I called my buddy who has a GTO and he said he puts in 6 1/2 quarts. I measured everything while I was filling it and I ended putting in about 6 quarts and 8 ounces. 6 1/2 quarts would be about 1/4 inch over the full mark and I don't like that. (Although it wouldn't hurt anything.) So, the book is wrong. It should take 6 1/2 quarts. Not 5 1/2 quarts. And I did torque the oil pan bolt down, even though I didn't really have to. But, thanks for all of your help. I've been changing oil for 40 years but you never know when you might miss something. That is why I wanted to be sure. Thanks again.
Old 05-02-2013, 04:03 PM
Like dem Vettes
Like dem Vettes's Avatar
I use a Mobil 1 oil filter.
Old 05-02-2013, 04:22 PM
Jimmy W1
Jimmy W1's Avatar
If I did what my manual says I would be one quart low. Read my previous post, please.
Old 05-02-2013, 04:29 PM
billyboy47
billyboy47's Avatar
St. Jude Donor '17
i bought the fumoto oil drain plug from amazon. i believe the part # is f107 if not mistaken. take out the original plug (keep it in tool box or whatever) insert the fumoto and push the lever to dispense the oil into the pan. never have to take it off, works like a charm due to the fact it saves time. lol
Old 05-02-2013, 04:37 PM
01VETTECOP
01VETTECOP's Avatar
One Quart low is not that bad.
One quart More is a lot worse for your motor !
Old 05-02-2013, 04:39 PM
IrishSpuds
IrishSpuds's Avatar
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Whoa - thats kind of personal. My wife torques my bolt I dont want to have to myself, but if the oilpan benefits, well just maybe...
Old 05-02-2013, 05:21 PM
fmarshall
fmarshall's Avatar
I have a grandsport. I torque both drain plugs and the oil filter to specifications in the service manual.
Old 05-02-2013, 06:59 PM
Jimmy W1
Jimmy W1's Avatar
but thanks for your help. And I really did appreciate everyone's help.
Old 05-03-2013, 01:32 PM
luvchevs
luvchevs's Avatar
What are the specs?
Dave
Old 05-03-2013, 02:08 PM
  #33
twinarrow99
twinarrow99's Avatar
Related question- getting ready for my first GS dry sump change - do the drain bolts have crush washers? If so, you all are replacing each time, right?
Old 05-06-2013, 07:43 AM
  #34
GOLD72
GOLD72's Avatar
Received 1,106 Likes on 718 Posts
GM engine drain bolts haven't used plastic or aluminum crush washers in a very long time. What is used is rubber and is shaped like a flat washer with an integral o-ring. Generally it can be reused but I like to replace every 4 or 5 oil changes because rubber like plastic will evenually suffer the ravenges of heat and time. You won't be happy after a fresh oil change if there is a slow seep from the drain plug.
Old 05-06-2013, 04:19 PM
  #35
Seadawg
Seadawg's Avatar
Not necessarily..... They actually recommend to overfill the base C6 vettes by 1 quart if you are tracking/racing your vette, as per page 9-5in my 2011 owner's manual. Here is the quote:
"Except ZO6, ZR1, and Grand
Sport:
Be sure to check the oil
level often during racing or other
competitive driving and keep the
level at or near 1 L (1 qt) above
the upper mark that shows the
proper operating range on the
engine oil dipstick. After the
competitive driving, remove
excess oil so that the level on
the dipstick is not above the
Old 05-06-2013, 04:21 PM
  #36
Seadawg
Seadawg's Avatar
Originally Posted by luvchevs
What are the specs?
Dave
18 lb. - ft. for the 2 drain plugs, and 22 lb. - ft. on the filter. Not much.
Old 05-06-2013, 07:03 PM
  #37
calemasters
calemasters's Avatar
I was wondering how many post before someone answered the question.
Quick Reply: Do you torque your oil pan bolt?
