New shifter
Received 1,597 Likes
New shifter
Just finished installing a MGW shifter in my 13 GS and I can say that this is absolutely the best "bang for your buck" mod that I have made to date in ANY of my cars. I had read all the hype and thought "can it really be that good ?" Answer YES ! I had not driven a stick on a regular basis for several years before getting the GS, and I thought I was a little rusty. Nope, now I can blame it all on the shifter. I also went to the round MGW handle which also made a huge difference. I am a palm shifter, and the stock handle never felt right. Now the changes are buttery smooth and accurate, even those made in anger. I also Dynamatted the tunnel area while I had everything apart, this also made a huge improvement in noise and heat reduction. Jegs sells a 4sq ft roll that covers the entire tunnel from front to back with minimal trimming. If anyone is on the fence about changing shifters don't be, just do it !
Welcome to the MGW club, it is a great mod and one every manual owner should do
I too have the round shaft, but have not installed it yet. I want to be able to have more shift ball options. Like you not a fan of the OEM shift ball and have an aftermarket round ball installed. The aftermarket old school round ball along with the MGW makes a world of difference.
Also would add MGW sets the standard on DIY instructions for all to follow.
I end up fighting the shifter it is to precise in the shift pattern if I shift in a hurry i end up in between or in wrong gear. Now this was with a hurst unit.
z51vett
z51vett
After 48k miles, the oem shifter's 3rd gear hang up was only getting worse. Now with 55k miles since the install of the MGW shifter, I have not had any hang up issues with 3rd gear. Shifts are precise, short and confident, just the way it should be. MGW is a quality product and made in USA, I wouldn't expect less. :
Thanks for your review.
Now that they have their shifter box in production I am thinking about it......and I agree a round **** is WAY better than the angled, awkward OE ****. Just changing ***** made a big difference for me.
I ordered it online from MGW, it was shipped in about a week for less than $250.
I agree with the straightforeward installation, but mine did not come with any instructions. I used the wealth of knowledge here on CF to remove the console and trim, then used the excellent install video on MGWs website to install the shifter. I agree that made in the U.S.A. does make a huge difference !
Will this fix the 3rd gear shifts. When I first got he car I hit 3rd every time without a single problem. Then all of a sudden one day I started missing 3rd but only at higher rpm ranges. It feels like I'm not really missing 3rd it just wont go in smoothly.
1 Post
And yes driveway DIY and can still use OEM shifter, just make sure you buy the right shaft when purchasing the shifter.
1 Post
How much of a difference is their lower box supposed to make? Anybody have one of those in? I understand it's pretty new.
Also, Is there any video or instruction out there on the center console removal (and much more importantly, reinstallation )?
