Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-28-2013, 04:45 PM   #1
NARIMAN
CF Senior Member
NARIMAN's Avatar
Default need to add brake fluid
i need to add brake fluid
is there any brake fluid that i can buy in autozone or wall mart?
what kind?
NARIMAN is offline   Reply With Quote
Old 04-28-2013, 04:48 PM   #2
Gering
Tolero Apto Victum
Support Corvetteforum!
Gering's Avatar
RWHP - 440.786 RWTQ - 439.494 I love to drive!!! http://togetherweserved.com/ http://www.coasttocoastam.com/ http://www.survivalistboards.com/
I like & use motul 600 rbf.
Gering is offline   Reply With Quote
Old 04-28-2013, 05:12 PM   #3
truckplay
CF Senior Member
truckplay's Avatar
Send a message via AIM to truckplay
Default don't add brake fluid
find out why it's low. pads may be worn or you have a leak. replace the pads or flush the brake fluid, but check it out first.
__________________
Tom
truckplay is offline   Reply With Quote
Old 04-28-2013, 06:00 PM   #4
SUB VETTE
CF Senior Member
SUB VETTE's Avatar
I use Motul 600 also for its high boiling point; but for average, normal daily driving Prestone is fine (and cheaper) which you can buy at Walmart.
SUB VETTE is online now   Reply With Quote
Old 04-28-2013, 07:11 PM   #5
NARIMAN
CF Senior Member
NARIMAN's Avatar
thanks
it is low because i removed the line that connects to caliper and it leaked some
i do autocross some times, should i get Motul?
also i was wondering to get HPS pads is it worth it i am going to fill the diferents?
Old 04-29-2013, 01:21 PM   #6
SUB VETTE
CF Senior Member
SUB VETTE's Avatar
I'd say it's worthwhile to use a higher boiling point fluid such as Motul in any track event that you will be putting a lot of repetitive high demand on your braking system. Using high performance dedicated pads for track use only is also a good move.
Old 04-29-2013, 05:43 PM   #7
florida john
CF Senior Member
florida john's Avatar
what kind?
Buying a brand name from Wal-Mart is fine, but buy the DOT type recommended in the manual.
If you disconnected the line to a caliper, I would strongly suggest bleeding the fluid at that caliper if you didn't already to that when reconnecting. But if you did bleed it, you wouldn't be asking about fluid! Any air bubbles in the line could come back to cause big problems during spirited driving or on the track. We don't want to see your brakes going soft on one corner of the car when you really need them! Air bubbles are compressible and brake fluid isn't. Get rid of the bubbles!
florida john is offline   Reply With Quote
Old 04-29-2013, 05:56 PM   #8
Cratchet
CF Senior Member
Cratchet's Avatar
DOT 3 is good.
Cratchet is offline   Reply With Quote
Old 04-29-2013, 06:17 PM   #9
truckplay
CF Senior Member
truckplay's Avatar
flush it all out, just don't mix fluids, contaminating it will cause problems. it doesn't hurt to run DOT4 on the street even though it's factory filled with DOT3. if you are going to track the car you will need the higher boiling point of DOT4. Hps pads work great in mixed use, street and light track.
Reload this Page need to add brake fluid
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
