Battery Tender
Battery Tender
With my car in storage but no electrical outlet at my storage house for a battery tender,would driving the car at least once a week keep the battery charged as normal? Can't move the car home till the garage gets cleaned out which could be a few months...
If you can't drive the car on a regular basis (do to weather or no time or whatever) you could pull the battery & store it up at the house or just disconnect one term so there is no voltage draw, should last a few months & be ok.
Disconnect the negative terminal -- the owner's manual recommends it.
Pg 5-49:
For extended storage of the vehicle, remove the black, negative (−) cable from the battery or use a battery trickle charger. This helps maintain the charge of the battery over an extended period of time.
http://www.gmpartshouse.com/download...09corvette.pdf
Pg 5-49:
