"I wait for my oil temp to reach XXX before going full throttle...."
Old 04-26-2013, 01:57 PM
ny32182
ny32182's Avatar
Default "I wait for my oil temp to reach XXX before going full throttle...."
I've seen a number of people post this with various numbers... any rhyme or reason to look for a specific number?
Old 04-26-2013, 02:33 PM
mundo
mundo's Avatar
That's basically saying wait till the engine warms up before stomping on the gas. That's common sense. When the oil temp is above 200 degrees the engine is probably warmed up.
Old 04-26-2013, 02:47 PM
R0NIN
R0NIN's Avatar
I like to baby my coupe... I'll pull out of my parking spot at 100 degrees oil temp.. then won't open it up until I get at least a few minutes of easy driving.... The OAT around SoCal right now is about 70 degrees though... so I'm probably just wasting gas...
I think my real issue is the clutch fluid... it seems like my vette it easier to shift when the clutch fluid gets nice and warm..
Old 04-26-2013, 03:06 PM
ny32182
ny32182's Avatar
I've seen 165, 180, and now 200 as good temps.
It takes me probably 10-15 minutes of normal driving to reach 165, and quite a while to reach 200.
Old 04-26-2013, 03:31 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
If I had to wait for my oil temp to get up to 165 before going WOT on my Z06, I might as well have gotten the V6 with the two barrel carb engine option as I would never be able to use anymore than 150 HP unless it's August and the ambient temp is 95 degrees.
Old 04-26-2013, 03:34 PM
ny32182
ny32182's Avatar
I'm talking LS3 if it matters.
Old 04-26-2013, 03:43 PM
topend182
topend182's Avatar
I personally do 160, but I have heard the c5/c6R teams go ***** out beginning at 120 F.
I always laugh when I see people starting their cars cold and within 30 seconds are at WOT shooting down the block. I can wait the extra few minutes for the oil to reach a proper level of viscosity before going WOT. I run my cars very hard when I'm racing, but I baby them up until that moment.
Old 04-26-2013, 04:04 PM
vig1116
vig1116's Avatar
i stomp on it as soon as i start it to get it to warm up quicker, then once it's warm they say it's ok to stomp on it....
Old 04-26-2013, 04:20 PM
Larry/car
Larry/car's Avatar
There you go.
Old 04-26-2013, 04:25 PM
BSE1956
BSE1956's Avatar
I don't do WOT, but if I get on it a bit, I wait for at least 185 or so.
KX
KX's Avatar
Why laugh, do you think they are doing major harm to their engine??!!! Not at all. I worked major highway construction going to college. Hell man, it was fire up those babies and get moving. No time to sit around and wait for temps. In 4 years I newer saw an engine blow.
But I do know of one story or perhaps a wives tale that involved the LT5 engine in C4 ZR-1's:...the story goes that someone in Bowling Green was assigned the task of moving cars around the lot after they were built. Apparently one very frigid morning this lady fires up an LT5 and immediately floors it.....poof, up it goes. Keep in mind that an LT5 has an enormous amount of moving parts including those 4 cams and two timing chains, etc. Still in all, that is the only case I have ever heard of an engine blowing because it was cold!
And yes, most Corvette owners baby their cars and do warm them up....I guess I just do it to any car out of 55 years of habit!
Old 04-26-2013, 04:30 PM
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
I baby it until 100, then drive normal until 130 or so then I just do whatever
Old 04-26-2013, 04:37 PM
C7 Mathis
C7 Mathis's Avatar
I usually wait for at least 150-160, sometimes even 180 but I'm centri Supercharged if that means anything for you.
Old 04-26-2013, 04:39 PM
Kvothe
Kvothe's Avatar
I just did a thread on this not long ago:
http://forums.corvetteforum.com/c6-c...ic-number.html
Old 04-26-2013, 04:41 PM
Boomer111
Boomer111's Avatar
Lets not forget that they will rebuild their engines seasonally if not more often. Most corvette drivers are looking long term engine health.
Old 04-26-2013, 04:46 PM
not08crmanymore
not08crmanymore's Avatar
I think you can warm it up while you drive it but I let mine warm up to around 100 or higher because that's what I am comfortable doing. GREG CARROLL of Carroll Supercharging in NEW JERSEY, and later BLOWERWORKS, of some years back told me 180 and that just stuck in my head for some reason.
Old 04-26-2013, 05:47 PM
dvilin
dvilin's Avatar
Received 7,929 Likes on 4,810 Posts
Sometimes I can not resist and go WOT before it is properly warmed up.
To "I wait for my oil temp to reach XXX before going full throttle...."
Old 04-26-2013, 05:56 PM
Gering
Tolero Apto Victum
Support Corvetteforum!
Gering's Avatar
WOT between 120F to 140F.
Old 04-26-2013, 05:58 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,099 Likes on 810 Posts
150ish and I used to do this on my blower Vette and it performed perfectly while I had her
Old 04-26-2013, 06:24 PM
PittMD1
PittMD1's Avatar
I don't ever go WOT. I won't take the rpm's past 2500 until it is at operating temp 185 - 200.
There was another post where someone said it takes 15 - 20 minutes of normal driving to reach 165. You must be talking when the air temp is -20. It only takes me about 5 minutes just putting through the burbs and she is ready to go.
Quick Reply: "I wait for my oil temp to reach XXX before going full throttle...."
