Jacking a C-6 Coupe?
Looking through my owners manual the pictures of the jacking points are not that clear. Anyone got any suggestions for jacking up and using jack stands? Any photos would be a great help. Thanks.
Dan
Dan
Dan,
You've come to the right place. There are literally hundreds of threads on here depicting every scenario one could think of in which to lift a C6. Use the search function and you'll find them. It would be impossible to list them all in this thread.
Cliff's notes: Most people like to use a crossbeam adapter with a super low and long jack to lift from the preferred jack points.....then either stand it on the beams using saddle jack stands or use flat top jack stands at the puck locations.
You'll find a wealth of information here.
Good luck.
Good luck.
The provide images above are great, but I also place my jack stands at the frame locations. I jack the front up with my jack and a 2x4 at the front cross member place the jack stands under my pucks in the front frame locations, then go to the back and jack up the rear and place the jack stands in the rear frame locations with my pucks in place. Did it that way on my C5 and doing it on my C6 with no problems.
