Painted my barrels, calipers & rotors
Old 04-23-2013, 06:14 PM
ButchN
Support Corvetteforum!
ButchN's Avatar
Default Painted my barrels, calipers & rotors
I did like a couple of others on the forum did with their wheels & painted my barrels, calipers & rotors last week.
I did not use the G2 system. I used what I found worked very well when I had my 82 coupe, POR15. It comes as a very complete kit & is easy to apply.
I bought a kit for red, a kit for black, & a 2nd 8 oz. can of black, which I just started dipping into when doing the 2nd coat.
I put 2 coats on everything & when it came to the caliper lettering, the chap stick "trick" did not work so I took a razor & ever so slightly slid the blade down the sides of the letters to cut the excess paint off & clean up the letters.
Here's the POR kit I used:
Here's the rotors & calipers original:
Then painted:
The insides of the wheels:
The wheels on the car before:
And after:
And a couple of shots on the car before & after:
Old 04-23-2013, 06:17 PM
spdkilz911
spdkilz911's Avatar
Looks great I have this on my to do list, just need to find the time.
Old 04-23-2013, 06:20 PM
GotVett?
GotVett?'s Avatar
Old 04-23-2013, 06:25 PM
elizavette
elizavette's Avatar
How much was that kit and where can i find it??
Old 04-23-2013, 06:38 PM
FlyerVette
FlyerVette's Avatar
Very nicely done.....Congrats...!!
Old 04-23-2013, 06:41 PM
Biggie G
Biggie G's Avatar
very nice, time to lower that bad boy
MakoShark72
MakoShark72's Avatar
Awesome, a huge improvement!!
Old 04-23-2013, 06:44 PM
EVRose
EVRose's Avatar
That turned out great. I definitely need to do something with my wheels too. That gray is just bad.
Old 04-23-2013, 06:49 PM
VET4LES
VET4LES's Avatar
Beautiful.
Old 04-23-2013, 06:50 PM
forg0tmypen
forg0tmypen's Avatar
Fun fact: GM Cup wheels are painted inside in the barrels. First for a C6 wheel.
Old 04-23-2013, 06:52 PM
R&L's C6
R&L's C6's Avatar
Received 1,251 Likes on 707 Posts
Very nice and looks professionally done.
I cant understand why people pay several hundred dollars to powder coat them when they look as good as yours for twenty bucks.
Old 04-23-2013, 06:53 PM
Biggie G
Biggie G's Avatar
I just noticed it's Por15, thats high quality stuff, it get used on submarines tanks etc....
they also sell good paint to help you stop rust, the paint is made specifically for it and to strenghten it.
Old 04-23-2013, 06:57 PM
newskatercat
newskatercat's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Always wanted to do that! Looks good!
Old 04-23-2013, 07:10 PM
MakoShark72
I started using POR15 back about 12+ years ago. You could only get through a local "distributor" which was a guy selling out of his garage!
Back then the ONLY problem with it, was it would fade in direct exposure to sunlight (UV). We only would use it to paint the chassis, where exposure to sunlight was minimal. If topcoated, no problem.
Have they cured that issue??
Old 04-23-2013, 07:12 PM
su8pack1
su8pack1's Avatar
Old 04-23-2013, 07:15 PM
ProfessorDeath
ProfessorDeath's Avatar
St. Jude Donor '13-'14
that does look nice...
Old 04-23-2013, 08:29 PM
Top_Fuel
Top_Fuel's Avatar
Originally Posted by forg0tmypen
...GM Cup wheels are painted inside in the barrels. First for a C6 wheel.
I thought lots of C6 wheels had painted barrels...chrome Gumbies, for example.
To Painted my barrels, calipers & rotors
Old 04-23-2013, 08:41 PM
blkgs
blkgs's Avatar
Did mine a couple of weeks ago, on my Blk GS. I went with PPG black base (2coats) and 3 coats of clear. Sprayed with low pressure, high velocity gun. Rattle can VHT high temp on the rotor hats, kept calipers grey. Love the look, but now just hose the brake dust off the barrels
Old 04-23-2013, 09:28 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,099 Likes on 810 Posts
Originally Posted by GotVett?
Nicely done
Old 04-24-2013, 06:18 AM
Don-Vette
Don-Vette's Avatar
Great job!
Quick Reply: Painted my barrels, calipers & rotors
