Coupe versus Convertible interior panels interchaneable?
I tried searching but really could not find the answer. I have an opportunity to get some interior panels in a different color, but they come off a 2005 coupe and I need to know if it will fit in my 2008 vert.
I'm looking at getting the LH & RH door panels, under column steering panel (trunk & gas release), glove box panel, and LH & RH sill plates.
I do know the center console will not fit the convertible.
Any help is appreciated.
Moderator
Received 3,596 Likes
The panels will fit but there are holes for things - like the power top on the Vert. If your vert has a power top, the panel under the driver side will fit but there won't be a hole for the power top switch. you will need to cut that. You can get OEM parts from GMPartsHouse.com.
