Do I have Run Flats
Old 04-17-2013, 01:28 PM
Gearhead Jim
Support Corvetteforum!
Gearhead Jim's Avatar
Received 2,051 Likes on 1,362 Posts
St. Jude Donor '13
Originally Posted by newskatercat
Run Flats will have EMT on sidewall!
Goodyear runflats say EMT
Michelin runflats say ZP
Firestone?
Bridgestone?
Pirelli?
Old 04-17-2013, 01:34 PM
ALLEN007
ALLEN007's Avatar
Ok, another question for the smartest Corvette people I know. My front tire states: 51 psi max pressure and my rear states: 45 psi max pressure but there is 30 psi in all 4 tires. Is that ok?
Old 04-17-2013, 01:36 PM
50 4Ever
Wil Cooksey #256
50 4Ever's Avatar
Firestone?
Bridgestone?
Pirelli?
The GY Gen II Run Flats I had said ROF on the side - Run On Flat
cclive
cclive's Avatar
That is max only...proper cold pressure is shown on the doorjam sticker...30psi
Old 04-17-2013, 01:37 PM
MakoShark72
MakoShark72's Avatar
I appreciate all the great info.
I'm sure glad I didn't know they were not run flats before I went to Tampa the other day or I would probably have had a flat tire. Guess I better get me some Fix a Flat and a Nail Kit.
Seriously??? I have driven for over 40 yrs and had ONE flat on the highway.. I think you were probably OK...
Old 04-17-2013, 05:35 PM
Gearhead Jim
St. Jude Donor '13
Usually, but not always...
http://forums.corvetteforum.com/c6-c...flat-tire.html
Old 04-17-2013, 06:05 PM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
I agree. And btw, OP, that goes for any car and any tires on the car. There is always a max inflation pressure which has nothing to do with what that CAR is supposed to have in its tires.
The specification for your car is on the door (sometimes, older cars have the specification on the inside of the glovebox or console lid, or printed in the owner's manual). And it will almost always be way lower than the max tire pressure stamped on the sidewall of any tire. Just so you know.....
Old 04-17-2013, 08:12 PM
ALLEN007
ALLEN007's Avatar
I appreciate the good info!
Old 04-17-2013, 08:39 PM
phileaglesfan
phileaglesfan's Avatar
Only reason I mention it is that the traction control computer is looking for a particular ratio of revolutions per mile between the front and rear tires. If that ratio gets too far off from what is expected, then the computer will assume that some tire or tires is losing traction with the road. This can cause it to intervene and it will be very unexpected to the driver. I have never seen on the forum what the actual specification is, but if you are going to get new tires anyway, no reason not to get the OEM sizes to avoid possible problems.
Consider the Michelin Super Sports when you replace them. They are not run flats right now but the base C6 sizes (the correct ones) will be soon since the C7 has them.
Old 04-18-2013, 02:13 PM
Gearhead Jim
St. Jude Donor '13
Firestone?
Bridgestone?
Pirelli?
Thanks for the addition.
Or does it mean "Rolling on Floor"?
Old 04-18-2013, 02:34 PM
HRS KLR
HRS KLR's Avatar
Bridgestone says RFT
Old 04-19-2013, 04:06 PM
Rebel Yell
Rebel Yell's Avatar
Received 2,639 Likes on 1,702 Posts
What's bad about that is now that I know that I don't have run flats (thinking I did) and as loud as these tires are I can't imagine how loud run flats are.
Wait, what....I can't hear you because of all the noise these runcraps make....
Old 04-19-2013, 04:21 PM
  #33
Gearhead Jim
St. Jude Donor '13
A local autocross wizard had the original non-runflat PS2's on his Z51 car, then switched to runflat PS2's which he and his wife used to win the regional championships a few years ago. He told me there was no discernable difference in noise or ride between the two tires, and the runflats seemed to handle a little better.
The C5 Goodyear runflats certainly earned the name Runcraps, but newer designs are much better.
Old 04-19-2013, 06:33 PM
  #34
acesx4
acesx4's Avatar
Goodyear run flats where on my Vette when I purchased it they developed a bubble in the front tire so I switched to Firestone run flats smoother ride & less road noise!!
Old 04-19-2013, 07:53 PM
  #35
MTsVette
MTsVette's Avatar
Location: O'Fallon Illinois - Currently own a 2016 Z06 1LZ A8 Coupe
BF Goodrich G-Force T/A But to dark right now to see anything else. Thanks
I have BFG g-Force KDW's (aggressive tread) on my '06...they are ultra high performance summer non-run flats...I like them a lot.
MT
Quick Reply: Do I have Run Flats
