Is all "Dex-Cool" created equal???
Hi... My '12 GS Convertible just turned one year old. I noticed today that the coolant is just a small amount below full cold. I'm new to Dex-cool so help me out here...
The manual says, "Use a 50/50 mixture of clean, drinkable water and DEX-COOL coolant. If using this mixture, nothing else needs to be added."
I see that anti-freeze vendors like Prestone make a "Dex-cool. Is it ok to use something like a Prestone version of Dex-cool or should I buy coolant directly from GM???
And regarding the water to mix with the Dex-cool, see where the manual says (in more than one place) to use "drinkable water". But that seems to imply tap water and I saw many posts that said "do NOT use tap water"...
So is distilled water ok??? Or what regarding water???
So help me out both with respect to which Dex-Cool (Prestone versus GM?) to buy and what water to mix with...
thanks... bob...
thanks... bob...
Prestone Dexcool ...ok
The first thing I did when I bought my 05 2 years ago was the coolant change. I used the Prestone Dexcool and distilled H20 with no problems. This was the best combination I decided after research and feedback from the forum. My 2cents.
I think the 50/50 pre-mixed is more expensive. I recently flushed my system 3X using 6 gallons of distilled water. Used the full strength dexcool and saved a little money. My original dexcool was 5 years old and 41,000 miles. It still looked brand new when I drained the old stuff. I bought Autozone's brand - same stuff.
Received 2,059 Likes
St. Jude Donor '13
When I sent a sample of my 2009 factory-fill Dexcool to a lab, they said it had excessive hardness and they always recommend distilled water.
My local parts store stocks the AC-Delco Dex-cool (orange). I bought a gallon and mixed up a second bottle of 50% each of Dex-cool and Distilled water...
Only required about a pint to bring it up to Full Cold but I like the water to be full...
Does anyone know where the water goes in a new car with no obvious leaks??? Are there always micro-leaks that cause small amounts to vaporize over time???
Just curious... Anyway, thanks for the help.
bob....
bob....
I doubt if GM makes any antifreeze so chances are your getting Prestone or another premium brand. Absolutely use distilled water especially if your on well water. When I changed the water pump on the C4 I had AC Delco recommended distilled water in the instructions. It probably has something with the alu. blocks.
