** New Product C6 Ram Air Kit available from Top Flight Reproductions **
C6 Ram Air Kit
Our Ram Air intakes are all about improving airflow to your Corvette's engine. It's just a matter of superior design. Better airflow translates into a noticeable increase in power, acceleration and most importantly...bragging rights.
Any power modifications (i.e., cylinder heads, camshaft, headers, exhaust, programming, etc.) that increases horsepower output demand the higher airflow capacity of the Ram Air intake.
Back it up with test results. Airflow test Results for the C6 Corvette flowed 35% more airflow than the original factory intake system. The chassis dyno tests indicated an increase of 15 rwhp on an otherwise-stock LS2. The C6 Ls3 performance increased by 35 rwhp. All that by installing the Ram Air intake into a stock C6 coupe.
Factory
Ram Air Kit
Click Here to Buy
http://www.topflightrepro.com/corvet...formance.shtml
C6 Ram Air Kit
Factory
Ram Air Kit
Click Here to Buy
Nope. It's a "bottom feeding" CAI similar to the fbody ls1 intake lids. I had a ls1 Camaro with an aftermarket lid for 8 yrs and never had a an issue with water intrusion. I had a vararam on my c6 for 3 yrs that was driven yr round rain/snow/whatever with no water issues. Since there is no air scoop like on a vararam or vette-air there should be no concern of water getting into your intake and hydrolocking your engine. You are about as likely to hydrolock your motor with the ram air ss as you would with the oem intake. It shouldn't happen unless you are driving in DEEP water.
Ram Air did a YouTube video a month ago and they just finished editing it down. They installed the Ram Air “Hammerhead” intake on a Grand Sport C6 and made +23 rwhp without a tune and with a tune made +54 rwhp.
The weather was 95F / 85% humidity in Houston (not the best for getting big numbers). Again these numbers only show the airflow improvement and not the actual ram air benefit we offer. This was also a completely independent test. Ram Air supplied the intake and installed it, but the dyno, and tuning were done by 510 Race Engineering.
Here is a link to the video:
I am not bashing products like this, and they all seem to cost between $200 - $500 from different manufacturers and vendors. But what makes a piece of plastic and air filter cost so much? Is it recovery of engineering costs or do the materials really cost that much to manufacture. Just curious and I've wanted to ask that question for a long time. Thanks for any input.
it a Z06 (Michael Cole's of performance driving network) in the video not a grandsport.
i was actually there to watch this install amazing power gains from this unit.
