Power top vs manual: which is faster?
Silly question?--maybe. But I'm asking about practical, everyday situations, not a stat. The time starting from the moment you decide the top needs to change. I'm hoping to hear from convertible owners, hopefully the folks who have (or currently) own both.
And for all I know, the answer might be different for the top going down vs going up. I'm thinking mostly about the situation where you got caught with the top down & it needs to go up.
Manual top owners:
Power top owners:
And for both, this mid-west weather scenario:
PS, off topic, but I think everyone agrees that the power top would be more expensive to repair, but the same can be said for a power window vs manual. It's a convenience item that many people are willing to pay for.
Manual top owners:
- How often have you decided to keep the top up in case the weather turns bad?
- Can you close the roof without getting out of the car?
- If you're stuck at a light and it's started raining, do you have time to put the roof up?
Power top owners:
- Same questions... Considering how long it takes to put the top up, have you kept it up if the weather looks iffy?
- If you're stuck at a light, do you have time to put the roof up?
- 1-click e-brake trick: do you use it to get the top to go down while moving, and if so any trouble there?
- Cruising topless on a slow highway, about 50-45 mph, and it starts raining
- You pull over to put the top up
- Which car would have less water inside?
I have the power top and I have done it at stop lights before and I don't fear the weather. I can pull off the road and put it up pretty fast.
I think both would get the job done.
I over think everything. Scientist. (really)
Also, some folks want to sell me a manual top, even though (for a C6) power top is a "must have" item. Rule handed down from my wife. But the question about which is faster... I really don't know.
Still hoping to hear from someone with experience living with both
Had a manual top on my c5, my c6's have always had the power top.
The manual top is much faster. I would prefer a manual top but the power top is always included in the option package on my vehicle.
I have an 06 vert with manual top. In a hurry I believe I could raise or lower the top, starting from a seated position in less than a minute. Granted, I can't do it w/o getting out of the car but for the optioned price for a power top, unless it came in an options package, it wouldn't be worth the money.
Manual top owners:
Power top owners:
Manual top owners:
Power top owners:
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
The power top is more technical in its operation takes about 10 sec to go up or and down. The manual top has way less to go wrong mechanically. You have to get out of the car to put it up or down and it also takes about 20 sec to put up or down.
Let the rest of the car you are considering make your decision. The top is rarely a problem with either.
It takes less time if you were setting in a parking lot or driveway, but if your at a light, it can take more time to safely get out of your car, vs 1 click on the E-brake and put it up on a roll.
With a manual top I have left the top up more than with the power top in iffy weather.
Having owned both, I would go with the power top. Don't worry about it breaking, power tops have a good track record.
The manual is definitely faster to put up or down, if you don't count having to get out of the car to do it.
For me, strictly for the convenience of not having to get out, I have the power top.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
THIS ^^^^^^^^^^^ If you are in traffic or where you can't get well off the highway .................... Nah !
Responses: 1) Yep, you are worrying too much about the differences; 2) I have manual...works great, takes about 25 seconds from sitting in the seat, open the latch, get out, put seat forward, push button under rear hatch, lift up hatch, fold top into rear compartment carefully (so as not to catch or rub it), close hatch, get back in. 3) My decision was based on cost....didnt want to pay all that money that would have been required to get the power top when buying new. My 2008 is a base base convertible with automatic. 4) Satisfy yourself on which you want...as long as you dont mind getting out to open/close its no big deal.
NCM Lifetime Member
Simple solution ............ Buy a C7 All the tops will be power ! Better yet, they will open or close using the fob.
Beautiful car! And from a purely value standpoint, manual top might make more sense, as long as the car is in season and the buyer didn't have their heart set on it.
anyone disagree with the 18 second number for power top? If not it's starting to sound like I was wrong, and the power top is just faster, hands down.
I'm curious if a cable could be fitted that raises the tonneau, that could be operated while seated. (thread in c6 tech) If possible that would make the manual roof much easier to live with. Still in the feasibility check stage, though, insight welcome
