install request - radar detector
Old 03-22-2013, 08:02 AM
veloz
veloz's Avatar
Default install request - radar detector
anybody know how to connect a Cobra XRS-9345 Radar Detector radar detector to mirror on a '05 model..i have seen some pigtail connectors here but not for this radar...
Old 03-22-2013, 08:38 AM
MGretz70
MGretz70's Avatar
Not sure exactly what your asking, you mean power coming from your radar detector needs to be hooked into the pink & black wire of your mirror connection?
Here's a link that might be helpful: http://www.bugmanweb.com/c6/escort.html
Your power cord coming out of your radar detector should have two wires, a power & a ground. Just splice it into your mirror
Old 03-22-2013, 08:42 AM
veloz
veloz's Avatar
yes ,that's what i meant sorry...that link is very helpful..thanks..just wondering if there is a pigtail out there design for plug and play for this type of detector..i have seen it for Escort and others but not for a cobra....if not ill follow the link and it myself...
Old 03-22-2013, 09:19 AM
MGretz70
MGretz70's Avatar
Hmm that I can't help with, haven't seen one either. Is the power connection like these? http://www.buyradardetectors.com/Pro...cessories.aspx
If so just go to a radio shack and get you one and use that to splice into instead of using the original.
Old 03-22-2013, 09:37 AM
veloz
veloz's Avatar
yes it is...might just use their "hardwire" connection to the fuse box and be done with it...thanks
Old 03-22-2013, 10:01 AM
Landru
Landru's Avatar
Received 1,052 Likes on 825 Posts
You can.
Just know it probably won't be 'switched' meaning you'll have to remember to unplug the sucker yourself, else you know what'll happen.
Having a detector activate/deactivate with the ignition is, to me, one of life's pleasures.
Old 03-22-2013, 10:07 AM
Pat Salerno
Pat Salerno's Avatar
Originally Posted by Landru
You can.
If you use the heated seat fuse , it will be switched with the ignition.
Pat
Old 03-22-2013, 10:10 AM
Landru
Landru's Avatar
Excellent point, Pat.
OP, choose the right fuse & you'll be good to go for a switched circuit.
Old 03-23-2013, 09:17 PM
veloz
veloz's Avatar
great pointers guys,,thanks...
To install request - radar detector
Quick Reply: install request - radar detector
