6 disk player
if its stock you only can put one in at a time. i have 2008 with nav it was not a option to have 6cd changer. and no ipod plug with nav
I have an '07 with the Nav. system and I have the remote 6-disk CD changer in the the rear drivers side storage area.
'Stock' CD player's a single disc device, OTHO for a 6 disc player 6 discs are loaded one at a time 'til loaded.
BTW IIRC for NAV equipted cars a 6 disc changer was a factory available option. Doesn't help those who bought a pre-orderedcar from dealer inventory. Such is the case for me.
I can't believe so many of you are geting this wrong.
If you have NAV you don't have a 6-disk player.
My '08 does not have NAV and I have the 6-disk player. It also has the plug for an MP3/Ipod device.
BTW, you load all the disks in the player in the dash. It is not a separate unit.
That said, I haven't played a CD in it for years! That's what an iPod will do for you.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
Ditto, but it is "had the 6 disc in the rear storage box". As a matter of fact, I have that 6 disc unit sitting in my attic and for sale.
If I recall, in my convertible, it connected under the waterfall in series through the XM radio module and then ran to the back to be located in the drivers side storage box.
Elmer
I have a 2012, and investigated the rear mounted player. Starting in 2009, I think, the player was no longer available - no wiring in the rear, no control from the head unit.
I have one but don't use it. CD skips pretty easy on uneven roads.
I'm thinking this is correct. You can transfer more than 6 CDs to a single MP3 disc which the nav will play. Changers don't make sense after MP3 was introduced in 2005. MP3 discs don't make a lot of sense after IPod connection was added.
No, that's a 6-disk CHANGER. The 6-disk player radio/cd combo where you feed all 6 CD's into the player in the DASH is separate from the NAV. You cannot have NAV and have the 6-disk PLAYER. Of course you could have a separate CHANGER unit with NAV.
