c6 convertible tips
If it has the power top make sure that it is functioning by putting it up and down 2 or three times and check the interior headliner for rips near the rear upper corner of the side windows.
From another thread on the headliner areas to check:
I have had a few convertibles so here goes, I stick with the dark top usually black. The light colors show crease marks or in sticky climes-mold specks. But they look good when clean so-choices choices. Good luck cutnout
i have an 06 vert - manual top. simple. takes abt 20 seconds to put top up or down. i see no reason to go with power top = $ and if it doesnt work it will b when its raining and u need it.
I have owned around 20 vette converts and had not owned one with a power assisted top since my 57 fuelie. I have had both the manual and power top and didn't think it was a big deal until I had the C6 with a power top, after having the power top I would not go without the convenience of putting it up or down without moving from the drivers seat and for me it is now a must have.
This photo shows the lite oak top on my 2001 when it was 10 years old and had 95k miles on the car. Just used
Raggtopp cleaner and conditioner products on it once a year.
I have an 08 and never have had any issues whatsoever and my top has been up and down A LOT. Cant help you with what to look for.
I would personally go Power Top. I have owned many verts over the years both manual and power. I wouldnt even consider a vert unless the top was power. Just my opinion.
the top frames are poorly designed, The frame will catch the headliner and tear the crap out of it . at 450 a pop , it sucks. In post #2 the top circle is where the frame catches the headliner and then its a done deal.
The power top comes with a tool that allows the top to be put up or down manually if needed.
I bought an 06 grey over silver one owner always garaged vert in July. The top looks like new. I can tell it wasn't stored down for extended periods or when dirty. That's how creases start. It is a manual and very easy to put up or down but you can't do it while seated. Still, about 30 seconds is all it takes. Inspect it closely inside and out for wear or rips, even repaired rips, small over sewn spots. Don't use brushes to clean it as they can catch and snag the material. I watched the workers where I occasionally take mine for a wash and they used soft sponges and immediately rinsed and then blew the material dry with an air hose. They also placed bags over the mirrors during the wash....hadn't occurred to me but I can see the value in it now.
The only thing I use for cleaning the dust out of the top is a horse hair shoe brush and it never does any damage as the bristles are soft enough to not do any damage.
This is a photo of my 2007's 6 1/2 year old top a couple of days after it had been down for two months straight:
