Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-10-2013, 08:02 PM   #21
need-for-speed
CF Senior Member
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03-'05-'07-'09-'10
need-for-speed's Avatar
Quote:
Originally Posted by cclive View Post
How does that compare to cleaning it with WD-40?
the 30 gets the job done and it's 25% cheaper
need-for-speed is offline   Reply With Quote
Old 03-10-2013, 08:11 PM   #22
cclive
CF Senior Member
cclive's Avatar
Quote:
I looked for it today at Walmart but they only have the more expensive stuff....oh well...
cclive is offline   Reply With Quote
Old 03-10-2013, 09:40 PM   #23
Gearhead Jim
CF Senior Member
St. Jude Donor '13
Support Corvetteforum!
Quote:
Originally Posted by duramaxsky View Post
I had a spare made and keep it on my key ring incase I lock the fob in the car or trunk. I am thinking about getting a spare fob and programming it to the car. Then take the battery out and hide it in the trunk. I think it will still work in the glove box without the battery. Then I could get home if I loose my fob.
Most people say the fob will work in the glove box even with no battery in it, but a few have said it won't.
I have a third fob programmed, battery installed, just wrapped in a couple layers of aluminum foil and hidden deeply inside the car. I've done a lot of testing and the doors/trunk will not open because of that fob.
There is also a hidden key outside the car, but I ain't gonna tell you where that one is either...
Gearhead Jim is offline   Reply With Quote
Old 03-11-2013, 12:55 AM   #24
bud miller
CF Senior Member
bud miller's Avatar
typo...must be the time change
bud miller is offline   Reply With Quote
Old 03-11-2013, 12:58 AM   #25
ChevyDave
CF Senior Member
ChevyDave's Avatar
Quote:
ok, so ya got me. i confess i actually looked it up in Google. And no, it was never made..... i can now vouch for that fact
and i am much smarter for researching.. lol
http://en.wikipedia.org/wiki/WD-40
the best part of the wd-40 story is... Larsen was attempting to create a formula to prevent corrosion in nuclear missiles, by displacing the standing water that causes it. He claims he arrived at a successful formula on his 40th attempt
so......... any ones of you out there, that wants to know how to prevent corrosion on your NUKES, just ask, i got the answer!!!!
ChevyDave is offline   Reply With Quote
Old 03-11-2013, 06:52 PM   #26
bud miller
CF Senior Member
bud miller's Avatar
anyway, more than one of my friends was unable to use their key in the hatch, because of dirt/corrosion and could not get hatch open...some broke their key...wd40 cheap prevention.
actually if we drive our cars more often , should'nt have a battery issue..........
Old 03-15-2013, 11:18 PM   #27
need-for-speed
CF Senior Member
CI 1-4-5-8-9-10 Vet
Quote:
It does work
While I had my fob opened up in order to replace the battery, I tried it. I put it in the glove box slot with no battery in it. The first time I pushed the start button, it made the clickity click sound. Then I pushed it again and it started right up
__________________
Mike M. NCM Member since 2000
2008 3LT Coupe, MN6, Z51, NPP, QX1 comp gray wheels, R8C
2008 Silverado Ext Cab, 5.3L, 2LT
2008 Tahoe LTZ (hers)
1979 Camaro 355, Edelbrock heads, intake, carb, hooker headers, 262 cam, 3.42 posi, 700R4 w/ TCI lockup kit
My Motto: "He who robs Peter to pay Paul can always count on the support of Paul"
Old 03-16-2013, 12:51 AM   #28
Rapnrev
CF Senior Member
Rapnrev's Avatar
The key in the fob must be for cars newer than 06. Never minde found the answer in a post I didn't read.
Rapnrev is offline   Reply With Quote
Old 03-16-2013, 11:30 AM   #29
CO Lightfoot
CF Senior Member
CO Lightfoot's Avatar
Most people say the fob will work in the glove box even with no battery in it...
Worked in my 09.
Makes a nice back-up fob for road trips.
CO Lightfoot is offline   Reply With Quote
Old 03-21-2013, 05:30 AM   #30
REDC4CORVETTE
CF Senior Member
REDC4CORVETTE's Avatar
Great info I used the key twist on both sides of my fob open right up!
Thanks guys.
REDC4CORVETTE is offline   Reply With Quote
Old 04-23-2013, 02:19 PM   #31
phylrick
Junior Member
phylrick's Avatar
phylrick
Default Wow.....what a relief!!
Bought my 2005 and have been shining it to death. All of a sudden personal features became erratic and I was in visioning days in the shop. Changed battery in fob and wha la!!!
All is well......great thread.
BTW....if your key won't work because of rust you ain't keeping the car clean......I thought all vette owners knew that!!!!!! Hehe
phylrick is offline   Reply With Quote
Old 04-23-2013, 02:34 PM   #32
LS WON
CF Senior Member
LS WON's Avatar
LS WON is offline   Reply With Quote
Old 06-14-2013, 10:36 PM   #33
2006c6keller
CF Senior Member
2006c6keller's Avatar
Default Go figure...
Good thought about the wife. Surprisingly, my wife's fob will release the key easily enough for her to do, but mine was the stubborn one. Go figure...
..., it is just the usual quality control for Vettes, always varing.
2006c6keller is offline   Reply With Quote
Old 06-14-2013, 10:49 PM   #34
2006c6keller
CF Senior Member
I do this except I loosen the FOB covers and put a piece of scotch tape doubled over sticky side to sticky side. I place this between the battery and the electrical connecting clips with long tape end sticking out. Then I only close gently and hold together with a rubber band, pull tape end out when need to use. In addition, I use a spare key attached to a convienent outside hidding place. Note: The FOB does NOT lose its memory when battery not connected, I tested it over two weeks later and it worked.
Old 06-14-2013, 10:56 PM   #35
2006c6keller
CF Senior Member
Default Yeaa!
Yeaa, we know, you are haveing a "senior moment" and can't remember!
Reload this Page Locked out of Corvette Battery Dead, How to OPEN FOB to reveal key?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
