whats your favorite front fender vents#1 GS gills#2 ZR1 vents or#3 427,base,ZO6 vents
If you had to pick your favorite C6 front fender vent which one would you choose #1 GS gills #2 ZR1 dual scoop vents or #3 427vert,base, ZO6 single slit vent? Just seeing where we all stand on what is the best looking C6 front fender vent.
IMO, it's hard to separate the look of the fender vents from their designated models.
Each doesn't quite look as good on the "other" models...
That statement makes no sense.
The side view of the fender vent is what visually 'separates', more like denotes the other models.
Originally Posted by marc8090
Z06, ZR1, then GS.
, but only on the 1st 2.
The GS should be after the coupe.
The gill look doesn't look apealling or 'clean' as the ZR1 & more notibly, coupe & ZO6, which has the larger opening the ZO6.
Did that make sense?
that's what I meant, but you stated it more clearly. I don't think one model's specific fender vent
would look better on a different model (ex: GS vent doesn't look good on the ZR1, etc).
hard (for me) to pick a favorite without considering which car are we talking about...
Reason: sp
