K&N Intake or Vararam snake charmer intake?
Anyone tried both?
Which one is better for daily drivers?
thanks
thanks
Jlang1 (08-25-2022)
OEM is best because you won't really gain anything after the 400-500 you spend on the other items.I'd personally go with VARARAM myself if i had to because it actually sucks in cooler outside air as opposed to being just a big filter that does nothing and possibly filters worse then your OEM does.You would get a very slight gain at speed (60+) mph with the VARARAM...1/10th of a second or so at the drag strip.Keep your oem though.Those are good for 436,505 and 638 respectively so what could really better?
Location: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Received 1,142 Likes
I bought a vararam for my 05 vert. It was a bit of fun to install, but the quality was decent. Nothing like the threads I read about when it first came out where people struggled with the install and the bad quality design. I think I only paid like 280 for it too. Got it from maryland speed here on the forums.
^ performance gain?
only at 60mph plus?
thanks
only at 60mph plus?
thanks
performance gain?
only at 60mph plus?
thanks
only at 60mph plus?
thanks
Between the two, definitely vararam since it draws cool ambient air. The ingesting standing water is HIGHLY unlikely with the VR while driving unless your are driving into some deep water.
If I run my car through a touchless high pressure car wash, I do turn the engine off just to be safe.(I'm sure I'm just being paranoid)
Truth be known the short amount of time the air is exposed to heat under the hood before being ingested into the stock engine intake doesn't warm it one degree. This time of year hot outside air isn't a problem, and in the summer so-called "Cold-Air-Intakes" are sucking hot air in right above the hot, hot, hot asphalt paving where you can fry an egg in no time flat. So please tell me, where is the "cold air" coming from? "Cold Air Intakes" don't do anything. K&N filters use far less efficient 1950's technology and filter out far less abrasives than the advanced technology folded filter-paper air-cleaners that come on your Vette. So, like when I was young and we removed the air-cleaner altogether to gain horsepower, which it did for a short-time, six months latter your engine produced less horsepower than when you used the air-cleaner. No native that live in India actually believe in "snake charmers", only dumb American tourists. Save your money and don't buy either. And totally ignore "testimonies" from any "shade tree" or "catalog mechanics" who bought these type products, they are simply trying to justify having spent good money on aftermarket junk.
My point is that I want to fix the lag in the paddle shifters which will necessitate a tuner. And I didn't know if there were any other minor replaceable parts which might enhance the tune. The operative word being "minor". I know that headers, full exhaust system, CAI and larger Throttle body will give me added performance. But at this point I don't want to do that...
The only inexpensive "minor mods"are CAI and ported tb which does improve throttle response. Having the A6 tcm tuned makes a big difference in the way the car drives/feels. The stock A6 tcm tune upshifts/downshifts are slow and mushy. The lag is really annoying.
Truth be known the short amount of time the air is exposed to heat under the hood before being ingested into the stock engine intake doesn't warm it one degree. and in the summer so-called "Cold-Air-Intakes" are sucking hot air in right above the hot, hot, hot asphalt paving where you can fry an egg in no time flat. So please tell me, where is the "cold air" coming from?
It has an ECS Efi live tcm tune on it but I just recently purchased hp tuners. ECM was Dyno tuned locally after a ported fast 102, long tube headers and catted x, vararam and 160 tstat. i did a dual bullet axleback and vmax ported tb after the tune. Waiting to hit the track in April.
A drag racer will pay more than $500 to gain a tenth.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Thanks!
Thanks.... YES, I've got a great way to get the most out of your Vette no matter where you live.
Give me a call and I'll get you set up right!
914-332-0049
Chuck CoW
