Horn quit working
Horn quit working
about 3 days ago I went to honk at a friend passing by and no sound came out. I rarely use my horn so I am unsure how long it has not worked I would say a couple weeks tops. The horn on the steering wheel doesnt work, pressing the panic button on the FOB no sound comes out either. With the hood popped and pressing the FOB you can hear the relay making a click in the engine bay but just produces no sound. I check the fuse in the engine bay fuse box and it looks to be good.
any ideas how this could happen or what I can do to fix it. If it is an expensive fix I may not even fix it because I rarely use it and when I need it my exhaust serves as my "you pissed me off" horn haha
Is there another fuse to check or is the only explanation the horn unit itself. How hard is it to fix?
you could switch horn relay #34 with something like windshield washer #36. switch fuse #2 with another same size.
i cant think the horns became unplugged, let alone even reach in to verify or check.
Joe Jorgensen (08-02-2021)
Oh okay, Ill try switching the relay and fuse with another to see if that fixes the issue. If it does not, would it have to be the horn unit? Is it easy to reach in from either above or below to check to see if it came unplugged or something like that, or does it require alot of things to be taken apart to get access to it?
I just tried switching the relay and fuse like you said and its still doing the same thing. You can hear the relay clicking when you press the panic button but no sound from the horn still.
i've seen removing and checking them and seems they did it from underneath, and they laughed about tearing their hands all up.. lol
i think they were removing the horn bracket so maybe wont be quite as hard.
i'll let others chime in, i;ve never tried to remove/check them personally
I would test the horn directly from the battery... But I am betting that is not your problem.
I would also test to see if the horn and relay are getting power and ground.
Do your headlights and windshield washer work 100% of the time?
I found a half dozen wires in my fuse block highly corroded and the headlight and washer were severed.
About an hour with .20 guage copper wire and I was able to replace all of the questionable copper.
All of my electronics now work again.
This is what the inside of the fuse block looks like. There are two sides.
If any copper is black, you might want to replace.
You can do this for around 10.00 or a new fuse block is close to 500.00.
This picture is the bottom view from before. You can see some corroded wires.
My friend had the same problem with her vette. A month later her car wouldn't start. As soon as she put a new battery in the car her horn started working again.
Worth a shot. Let us know
Lisa
Lisa
Thanks for the suggestions guys and gal!
My wipers and lights work without problem the only thing I have noticed to be not working is just the horn. I am hoping the wire harness from the horn simply came unplugged or something of that nature. After work today I am going to get under there and see if I can locate the issue. What is the best way to go about it? Jack the from up and reach in from the bottom? Or what pieces need to be taken apart to gain access?
About 2 year's ago the horn stopped working on my 06. Opened the hood and could see that the lead had come off. Just reached down in there and clipped it back on and it has been fine ever since. No jacking needed.
Okay I just finished my attempt at fixing the issue. I took off the piece that is underneath the fog light. I reached in and tried to feel the connector and it seemed to be clipped together. My car is supercharged and has a big tube right where that opening is so my work room was limited. The horn still isn't working but I couldn't really check into it all that much. I could only really check that one connector. Any other ideas guys?! I don't even know how I would get to it if the horn itself needs to be changed.
Also, correct me if I am wrong but if one of the horns went out then wouldn't the other one still be working but would just sound different. I find it strange that both quit at the same time.
