Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
- How to Install an Exhaust Enhancer Plate
Step by step instructions for do-it-yourselfers.
DIY Exhaust Enhancer Plate install with Pics
Below are the DIY instructions on how to install an exhaust enhancer plate.
It is very simple to install and takes all of 15 minutes to do For those who may not be handy with a wrench this is a beginners level DIY mod, and you will take pride after you install it There must be 20 styles of plates from various vendors on CF...pick the one that is right for you and have fun installing it...its very easy.
Note: Some exhaust enhancer plates will not work with NPP exhaust systems, so check before you buy.
Before
After
TOOLS
All you need is a 13mm socket with an extension
The Process
Crawl under your car from the rear and look up between the exhaust and you will see where the rear exhaust hanger is mounted. This is what you will see …….
Loosen the nuts (don’t remove) with your 13mm socket.
The plate has horizontal and vertical oriented slots. Slide the horizontal slot under the nut you loosened then rotate the vertical slot onto the opposite hanger bolt and secure. (hold in place with one hand till the nuts are snugged up or it will fall)
Here it is in place (apologies for the blurry photo).
Set back and enjoy your handy work!
Hope this helps someone!
John (aka JKbride)
Before
After
TOOLS
The Process
John (aka JKbride)
They will work with the NPP system depending on the plate. Mine came with two holes and no slots. I "customized" it so it could be installed without taking it all apart.
nice!
do you have a stock defuser?
where did you get the plate?
thanks
thanks
OP,
Thanks for the post!
I tried to mount mine last winter, with no luck. Since then, I forgot all about it. The mounting instructions provided by the vendor were difficult to read/comprehend due to the poor photocopy image. It was too dark. I should be able to master this mounting, now...
Appreach,
B
Appreach,
B
You can look here http://www.corvettemods.com/Exhaust-...tes_c_159.html
I think other supporting vendors have these as well.
OP,
Appreach,
B
Appreach,
B
Much easier for you. It took me damn near 45 min to install one on my Z. Could barely get my hands in there and I had to use an open ended wrench. Now i lost one of those bolts and im pissed. Guess i didn't tighten it enough
I just checked out your website and saw your advisory: "Tech Note: Will not fit Z06/ZR1's due to bolt hanger locations."
That bummed me out. I was thinking about buying the Centennial Edtion version for my ZR1. But no workie on my stock NPP.
Thanks for great instructions to install. I did this. Here's my issue. There's a vibration noise coming from it now. When I'm driving I hear a different sound. I can't get the bolts any tighter. Anyone have something like this?
Thanks.
Thanks.
