Recomendations for buying a C6
You'll hear about 2005s with "flying roofs". There were a good number of 2005s where the painted roof panel delaminated. In those cases, the outer painted panel became completely separated from the panel frame. The consequences if it happened at speed were, well, you can imagine. GM identified the cause and re-engineered the panel. Those of us with afflicted cars (myself included) got new painted roof panels and those panels have been free of problems.
"All cars have problems," as is so unhelpfully pointed out on this forum all the time, but not all cars (or model years) have the same number of problems.
Be Patient. Look around. After two C5s and with the stupid little things that went wrong, such as the LED in the climete controll to the head light motor gears. The great people in this Forum can keep you away from the Dealer with a real easy fix to the problem. I could go on all night with stories like when my Z06 would not pass emmisions, the dealer told me i needed to replace all the sensors in the cats that wern't coming on. BIG $$$. With the help of the forum, a battery disconnect and a 15 min. drive. She passed with no problem. Bottom line, No matter what Corvette you chose. There will always be someone here to help you.
After six weeks of ownership and not having a clue about any model year...
I chose 2007 because I figured all the first year bugs would be worked out.
Also the cost difference between the 2005 and 2007 were minimal.
I personally would look at the Tie Rods for worn out rubber.
If you hear belts chirping automatically knock 1000.00 off of the price or walk away.
The Harmonic Balancer is a bear to deal with.
Good tires is another must.
I thank everyone! This is exactly what I was looking for, and I agree %100 that the knowledge base on this forum is second to none! I will post if I get a C6.
Have a great summer, Atlas
