corvette forum thank you
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
welcome and good luck. expensive but probably worth every penny.
Welcome and good luck on the repair. Without a doubt the balancer is a weak spot on our cars and GM should be embarrassed that they left this problem continue for so many years.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Heh ........... That would be a good question to ask at the C6 "Ask the experts" seminar. Would be interesting to hear their answer ......
That's actually a good idea and think it would be appropriate. I know this forum is not a representation of all Corvettes, but the balancer problem seems to come up more than any other and pretty often.
got an 06 have not had ANY problems, since when did anything other then an 05 and a handfull of early 06's have a HB problem and when did GM not address them? C6 experts?
Simplify
Location: forging ahead...making up for lost time and embracing each day thankful to be alive.... nj
St. Jude Donor '13-'14-'15
~~~ CFOT Book Folder ~~~
Welcome. Great info here.
Remember to wave
Remember to wave
NCM Lifetime Member
NCM Lifetime Member
you have a steel ring mounted to another steel ring via molded rubber in between IT IS SUPPOSED TO MOVE! the only reson that the expensive one does'nt move back to front IS THAT IT IS SANDWHICHED INBETWEEN 2 SNAP RINGS PER RACING RULLES so you dont throw the outer ring. I hope you guys NEVER look at it from the front BECAUSE YOU WILL SEE IT RUN IN AN EGG SHAPE THEN WHAT ARE YOU GOING TO DO!
