traction control issue (VIDEO)
Old 02-21-2013, 11:21 PM
jwaldro2
jwaldro2's Avatar
Default traction control issue (VIDEO)
Sometimes when I hit the button it works but that is rare. Maybe its the switch bc I know the tc works bc if I spin the dic lets me know via the message. And sometimes it will turn off but that is rare. Let me know what you guys think!
Old 02-21-2013, 11:51 PM
ChevyDave
Support Corvetteforum!
ChevyDave's Avatar
OP... your attachment failed, i'll erase this when it is posted.. fyi
this is the link that OP tried to post...
http://static.photobucket.com/player...119_184858.mp4
Old 02-22-2013, 09:20 AM
jwaldro2
jwaldro2's Avatar
Thanks man I tried to post it from my phone which is probably why it didnt work. Anyone have any advice?
Old 02-22-2013, 11:12 AM
sevinn
sevinn's Avatar
St. Jude Donor '14, '16
I'd pull off the center console and check the connection to the switch. The connector for the TC button is pretty small, as well are the wires within it.
Old 02-22-2013, 01:41 PM
jwaldro2
jwaldro2's Avatar
Im an electronics major so I know some stuff ab electronics but I dont want to start messing with stuff and further the problem but I will probably end up taking it off
Old 02-22-2013, 01:48 PM
C6RaceCar
C6RaceCar's Avatar
Its the button. My 2011 had to go in for the same thing. Bad button. Took 20 minutes for them to swap it out.
Old 02-22-2013, 01:53 PM
jwaldro2
jwaldro2's Avatar
Have any idea on how much it cost?
Old 02-22-2013, 02:01 PM
ChevyDave
ChevyDave's Avatar
question... is the switch item #35 here? if yes, its part number 15148444 sold here..
http://store.gmpartshouse.com/parts/...icleid=1432739
Old 02-22-2013, 02:10 PM
vig1116
vig1116's Avatar
that button is cheap, maybe $10-25 new. I'd replace the button and go from there. To remove the bezel is super easy, i've done it like 20 times already....
Old 02-22-2013, 02:17 PM
ChevyDave
ChevyDave's Avatar
i had saved this DIY... you might have another link better than this one.
http://www.theredlion.us/GCA%20Cente...%20install.pdf
Old 02-22-2013, 02:24 PM
vig1116
vig1116's Avatar
this is the write up i used to remove the bezel. I'm sure it's pretty much the same as the other..... http://forums.corvetteforum.com/c6-t...l-removal.html
Old 02-22-2013, 03:16 PM
jwaldro2
jwaldro2's Avatar
Thanks guys! May have to get the cf bezel while I got it off! This will be a saturday afternoon project. Thanks for the replies
To traction control issue (VIDEO)
Quick Reply: traction control issue (VIDEO)
