Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-19-2013, 12:19 AM   #1
HANNY
CF Senior Member
HANNY's Avatar
Default lowering bolts SHOT
second set of lowering bolts i have installed on my 09. The car only has 12,000 miles so needless to say the bolts stink!!!! Wouldnt be right to call out the 2 different vendors i used "BUT" i can say i think most if not all the lowering bolts are the same. They just dont hold up and the rubber part wears thru quick, then starts to squeek, then wears into your control arm then youre really screwed. i corner pretty hard for sure but they should last longer then 6k per set.
This is just my experience and my driving habits arent like others who may not have problems with them but i did. I'm an ASE master certified tech who knows a little about stuff,,, i thot about going hardbar but with the idea they may rub a groove in the control arm i decided not to. The issue i have with the ones i have is weak/bad rubber product that just doesnt last.
Couple pics for lookin, be safe. pAuL
Click the image to open in full size.Click the image to open in full size.
HANNY is offline   Reply With Quote
Old 02-19-2013, 12:21 AM   #2
chets ls3
CF Senior Member
Mine looked like that. Buy hardbar lowering bolts. Seem to be better. Only downfall you have to lube them up well.
chets ls3 is offline   Reply With Quote
Old 02-19-2013, 07:16 AM   #3
LFZ
CF Senior Member
LFZ's Avatar
Yep...been there...don't that.
LFZ is offline   Reply With Quote
Old 02-19-2013, 07:36 AM   #4
JW@JWMotoring.com
Supporting Vendor
St. Jude Donor '09-'10-'11-'12-'13
JW@JWMotoring.com's Avatar
jmotoring jwmotoring C5ish
I've seen that quite a bit over the years with those kits. It's hard to believe they keep selling them. They have to know by now
JW@JWMotoring.com is online now   Reply With Quote
Old 02-19-2013, 08:08 AM   #5
AORoads
CF Senior Member
AORoads's Avatar
well, if it's not the vendors' fault, then it must be the manufacturers' fault---that's assuming (correctly, I presume) that you're not doing something wrong in the installation.
so, wouldn't it be helpful to either mention the manufacturer or the vendors---not to criticize them as vendors, but to warn others that the lowering kits don't seem to last? unless you think you've already done that by saying any you buy, other than hardbar which you haven't tried, won't last.
AORoads is offline   Reply With Quote
Old 02-19-2013, 08:45 AM   #6
speedraider
CF Senior Member
speedraider's Avatar
[QUOTE=HANNY;1583160676]second set of lowering bolts i have installed on my 09. The car only has 12,000 miles so needless to say the bolts stink!!!! Wouldnt be right to call out the 2 different vendors i used "BUT" i can say i think most if not all the lowering bolts are the same. [B]They just dont hold up and the rubber part wears thru quick, then starts to squeek, then wears into your control arm then youre really screwed. i corner pretty hard for sure but they should last longer then 6k per set.
This is just my experience and my driving habits arent like others who may not have problems with them but i did. [COLOR="Blue"]I'm an ASE master certified tech who knows a little about stuff,,, i thot about going hardbar but with the idea they may rub a groove in the control arm i decided not to. The issue i have with the ones i have is weak/bad rubber product that just doesnt last.
sure it would, they all know their selling absolute crap
speedraider is online now   Reply With Quote
Old 02-19-2013, 10:00 AM   #7
chets ls3
CF Senior Member
If I have issues with the hardbars I will go to a stock bolt and cut a rib.
I was very surprised to see the torn bolts like above didn't groove my LCa though
Old 02-19-2013, 11:14 AM   #8
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Time to go coilovers for lowering with no issues.
peter pan is offline   Reply With Quote
Old 02-19-2013, 11:43 AM   #9
switchblade six
CF Senior Member
switchblade six's Avatar
Does this only happen in the rear...I want to lower as well and am aware of this issue so was going to cut a rib on stock...the rear has twice the rubber surface area so they must be under much more stress
switchblade six is online now   Reply With Quote
Old 02-19-2013, 12:24 PM   #10
chets ls3
CF Senior Member
My rears were tore more than the fronts. Fronts tear too
Old 02-19-2013, 01:14 PM   #11
CandyRed77
CF Senior Member
CandyRed77's Avatar
Quote:
I have hardbar bolts as well in the rear (for about 30k miles now) and used to lube them based on comments I heard on the forum. A few weeks ago I was doing my winter-cleaning and as part of that I always clean off and replace the grease. When I cleaned it off this time, I clearly noticed that the dirt that got caught in the grease had worn an indent in my control arm The arm is pretty thick at that point, so I'm not too worried, but I left them ungreased this time to see if it gets worse... and if there are any noises...
Sonny
__________________
Proud owner of:
2009 Jetstream Blue Coupe with clear top/black halo/35% tint, 2LT with HUD, 6MN, Z51, NPP with M2W, 18/19 CCW SP500 with Hankook Ventus 275/305, Bilstein Sports and some more small enhancements
1977 Candy Red T-Top, 17/18 Torq Trust II and some Edelbrock and VB&P goodies
CandyRed77 is offline   Reply With Quote
Old 02-19-2013, 01:29 PM   #12
chets ls3
CF Senior Member
Well I got caught in a monsoon last night. This morning hardbar bolts are squeaking their button off. Looks like I might go the remove a rib route. Also I haven't changed out the fronts but have a brand new set of hardbars for front too.
Old 02-19-2013, 02:04 PM   #13
Wah
CF Senior Member
Wah's Avatar
The stock ones wear out too; just take a longer time since the rubber part is thicker. The rubber part of the snubber actually rub on the control arm during suspension cycling because there is a difference in control arm and spring radii.
Wah is offline   Reply With Quote
Old 02-19-2013, 03:06 PM   #14
ZO ZICK
CF Senior Member
ZO ZICK's Avatar
Quote:
ZO ZICK is offline   Reply With Quote
Old 02-19-2013, 04:17 PM   #15
Drumhawk
CF Senior Member
Drumhawk's Avatar
I second this motion.
Drumhawk is offline   Reply With Quote
Old 02-19-2013, 04:43 PM   #16
LFZ
CF Senior Member
LFZ's Avatar
Quote:
I third this.
Old 02-19-2013, 05:54 PM   #17
chets ls3
CF Senior Member
Coilovers are high lol
Old 02-19-2013, 06:41 PM   #18
SuperchargedStroker
CF Senior Member
SuperchargedStroker's Avatar
I GOT TIRED OF BUYING PINS OVER AND OVER. I MADE THESE OUT OF SELF LUBRICATING UHMW. CHEAP AND NON WEARING. I have had my post taken down previously as they thought I was selling them and IM not a vendor. I am not selling them, just offering suggestion. Caps that go on the facotry pins, they have been on my car for 4 months and no wear thus far. Daily Driver too.
Screw paying up to $40+ a set. And to buy the Delrin ones, seriously this was way easier and alot cheaper and super easy to replace. I just pop the new one on when it wears.. Oh wait.. It hasnt.. LOL
SuperchargedStroker is offline   Reply With Quote
Old 02-19-2013, 06:48 PM   #19
SuperchargedStroker
CF Senior Member
The ride height is the same as the aftermarket in terms of low adjustability.
I have had no negative result so far. If you have a lathe I say get the material and make a set. If not, its not rocket science. A machine shop can wittle out a set in no time at all.
Material is like 20 bucks. I cut pucks from a rod of stock and then spun out the centers to fit. No squeaks, no grinding, and low height adjustable. I did put a little dab of marine grease despite lubrication from material but only so it wouldnt grind dirt in to the arms and material. I use alot of this stuf on automated cells at work, its good stuff (UHMW), and tough wearing.
Old 02-19-2013, 07:36 PM   #20
switchblade six
CF Senior Member
GM and Vendoers listen up!!!
Reload this Page lowering bolts SHOT
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
