Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-15-2013, 04:27 PM   #1
Reggied
CF Senior Member
Support Corvetteforum!
Reggied's Avatar
Default Simple clutch test
2005 Corvette.
What are the simple ways to see if you are in need of a clutch soon.
Just purchased used 2005 corvette, 6 speed manual.
How do I check to see how much life is on my clutch before I need to change the pad.
Reggied is offline   Reply With Quote
Old 02-15-2013, 04:54 PM   #2
schmegeggie
CF Senior Member
schmegeggie's Avatar
release the clutch with the brake engaged. Should stall the motor.
schmegeggie is offline   Reply With Quote
Old 02-15-2013, 05:01 PM   #3
calemasters
CF Senior Member
calemasters's Avatar
calemasters calemasters
Quote:
Originally Posted by Reggied View Post
2005 Corvette.
You can not inspect the clutch with the driveline assembled. The driveline support assembly must be removed to inspect the clutch disc, flywheel and pressure plate.
calemasters is offline   Reply With Quote
Old 02-15-2013, 05:06 PM   #4
C6RaceCar
CF Senior Member
put it in 5th when cruising around 30-40 and stand on the gas. The car will either lug or the clutch will slip and the motor will ring out.
C6RaceCar is offline   Reply With Quote
Old 02-15-2013, 05:20 PM   #5
CO Lightfoot
CF Senior Member
CO Lightfoot's Avatar
I'm guessing you're having clutch issues.
Take a look at your clutch fluid -- changing it might help. DIY with the Ranger Method.
CO Lightfoot is offline   Reply With Quote
Old 02-15-2013, 05:43 PM   #6
Reggied
CF Senior Member
Reggied's Avatar
Default Be proactive
I did change the clutch fluid last weekend. Car stalls per earlier instructions. So far no problems. I was asking because I am a proactive person. The car has 86K miles. I do not know the history of the car so I fix everything I think need fixing. This approach saves me money in the long run. Planing a road trip from GA to IL next weekend. I don't want to be stuck on the side of the Highway.
Old 02-15-2013, 06:09 PM   #7
seamus2154
CF Senior Member
These clutches have lasted over 100k if not abused. So not knowing I can understand. The test shown to me by an old mechanic is to try to start off in a high gear like 5th if it grabs and stalls that is good if it slips it is going to be a problem. Of course give it gas and try to get it to grab in 5th. Slips=bad grabs or stalls=good!
seamus2154 is offline   Reply With Quote
Old 02-15-2013, 06:17 PM   #8
Walt White Coupe
CF Senior Member
Walt White Coupe's Avatar
The standard way to test your clutch is to see if it will hold high torque at low rpm.
First try this: Drive at 40 mph in 5th and just floor it in gear. If the clutch slips you know it's really in bad shape and must be replaced.
If it didn't slip by just flooring it then try this more aggressive test: Take the car out on an open road and go about 40 mph with the car in 5th gear. Push in the clutch pedal and then while coasting simultaneously drop the clutch and floor the gas. If the rpm drops right down to what it should be in 5th gear with the car accelerating normally, your clutch is ok. If the rpm starts rapidly climbing beyond what it would normally do in 5th and the car not accelerating normally, your clutch is shot.
Walt White Coupe is offline   Reply With Quote
Old 02-15-2013, 06:24 PM   #9
z06clif
CF Senior Member
z06clif's Avatar
Try starting out in 3rd gear. If it grabs its good . Dont get on it just ease into it.
Clif
z06clif is offline   Reply With Quote
Old 02-15-2013, 06:41 PM   #10
PatriotZ
CF Senior Member
PatriotZ's Avatar
Location: "No matter where you go..............there you are" ..."You cannot drive a dollar bill" Remember..."Don't believe everything you think"
If it ain't broke....don't fix it....these clutchs are pretty reliable for 100,000 miles or so.....
PatriotZ is offline   Reply With Quote
Old 02-15-2013, 06:58 PM   #11
racebum
CF Senior Member
racebum's Avatar
all depends on how you drive it. i have seen cars with 240k on the oe clutch that were pampered around and cars with 20k that have the clutch coming out in chunks.
there is no proactive clutch test as failing any of the "tests" means you need one. clutches either grab or they don't. when yours slips or comes apart, replace it.
racebum is offline   Reply With Quote
Old 02-15-2013, 07:44 PM   #12
cclive
CF Senior Member
cclive's Avatar
Quote:
Originally Posted by PatriotZ View Post
If it ain't broke....don't fix it....these clutches are pretty reliable for 100,000 miles or so.....
If it passes the 5th or 4th gear test, make sure the fluid is clean and then enjoy the car.
cclive is online now   Reply With Quote
Old 02-16-2013, 02:39 AM   #13
CO Lightfoot
CF Senior Member
Don't try this kind of "burnout"...
Old 02-16-2013, 03:35 AM   #14
RULOOKIN
CF Senior Member
RULOOKIN's Avatar
I have always used the park on a hill method in reverse take your foot off the break and see if the car will hold on the hill !
RULOOKIN is online now   Reply With Quote
Reload this Page Simple clutch test
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
