Need Help glueing or epoxy nose panels
Upon the purchase of my C6, I notice an attempt to tack the nose panel to the side fenders. Well it came apart on my way home. I know it has to be a simple solution to fix this.
My car nose panel is bowing/flexing up on the corners where the nose panel meets the left and right front fender panels near the headlights. Enclosed is a picture where I am showing the panel popped up. The internal clip between the nose panel and fender panel is broken. Do anyone have an idea how to glue / epoxy / screw the panel down so they do not pop up from normal driving.
a) Is there an epoxy strong enough to hold this area together.
or just down.
b) Or a Clip to afix them together
or just down.
More infor
In the first picture I am using a blue plastic tool to show the opening I want to fix.
You can also see a black tacky substance which was used to attempt to hold the two panels together. I want to glue or epoxy or screw the two panels together. Is there an epoxy out there that can do the job.
http://www.aacorvette.com/pdf/aa_c6_fascia_removal.pdf
look on page 4 of the pdf you will see the clips you need there is a square and round one for each side
you need to replace the panel clips that connect the fender and front. there are two pieces on each side I will attempt to find the part numbers for you
Part numbers are in this thread:
http://forums.corvetteforum.com/c6-c...005-coupe.html
This is what I think is going on.
THe fender section have a bump that fits into a small hole in the nose panel. THe problem is the hole in the nose panel is tore. I hope the clips you find for me can be retro-fitted to hold the two panels together.
Most likely need to take the front fascia off loosen the fenders to replace the clips, and repair the front. The clips are known to fail..
Race Car Tech
This maybe of help as well. You say your facia is torn downward, but I think that slot is required to fit into the clip.
Here is a link that shows the clips and how the front facia should look to work on the clips.
http://forums.corvetteforum.com/c6-t...stay-down.html
