View Poll Results: Harmonic balancer failure poll
I have not experienced a problem
547
64.13%
I think I have a problem now
73
8.56%
I have replaced it once
138
16.18%
I have replaced it twice or more
24
2.81%
I have replaced it, but decided not to use a GM part and went for an aftermarket unit
71
8.32%
Voters: 853. You may not vote on this poll
Old 02-10-2013, 06:35 PM
  #61
gwyliecoyote
gwyliecoyote's Avatar
'05 replaced at 144,000 for the first time
Recommend this quality after market part - Chevy mechanic thought highly of it.
http://www.hinsonsupercars.com/p-146...7-11-c5c6.aspx
and this crank bolt:
http://www.hinsonsupercars.com/p-484...lt-ls1ls2.aspx
Also replaced all belts
Old 02-10-2013, 07:49 PM
  #62
fressh
fressh's Avatar
My 06 with 44,000 has a wobble and chirp now.I will be replacing it.
Old 02-10-2013, 08:50 PM
  #63
Goatdad
Goatdad's Avatar
St. Jude Donor '11-'12-'13
Originally Posted by MikeERWNC
That is because Math was never your stong point...
I guess I could have given you the full 10 min.
Old 02-10-2013, 08:54 PM
  #64
okie08vette
okie08vette's Avatar
2008 A6 with 40k and no problems.
  #65
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
I am replacing one tomorrow on a 98 coupe tomorrow, 60k miles. It came apart and slide backwards.
Old 02-10-2013, 11:02 PM
  #66
Mike Green9
Mike Green9's Avatar
'08 18,000 miles no problem.
M....
Old 02-10-2013, 11:38 PM
  #67
gbgary
gbgary's Avatar
based on this video i have it now. '07, 42k.
Old 02-10-2013, 11:51 PM
  #68
brooklync5
brooklync5's Avatar
Replaced mine along with the water pump at 20k miles
Old 02-10-2013, 11:55 PM
  #69
boraxman
boraxman's Avatar
It would be interesting to see failure vs. year
Old 02-11-2013, 04:27 AM
  #70
LNZ
LNZ's Avatar
2008 10.000 miles, No problems so far
Old 02-11-2013, 07:11 AM
  #71
MikeERWNC
MikeERWNC's Avatar
I would think Failure versus VIN.
The failure might be due to bad lots delivered to GM.
I am sure GM is not building these but if they are like all the other pulleys I have replaced on the car CHINA is clearly stamped on them.
Old 02-11-2013, 08:05 AM
  #72
RobLo
RobLo's Avatar
Based on your experience,the pictures posted earlier and the video posted by gbgary, it seems like they tend to separate ad go back into the engine. I guess that would be better than going forward into the steering rack and radiator, does everyone agree?
Old 02-11-2013, 10:51 AM
  #73
Chip A
Chip A's Avatar
Have any of you seen the results of a catastrophic failure of this part? What is the failure mode, and what do the innards look like after the failure. Based on your comments, the aftermarket units seem like they have better engineered interior materials and / or construction. Is there any reason to think that its life span is related to how the car is driven? I can’t get my head around the idea that some of these failures come early in a car’s life while others seem to happen mid-life or later. It would be interesting to see if there is any relationship to a given parts batch and a specific production run of cars. I wonder if any of the people that voted have C-5’s as that also would skew the results. It is pretty hard to come up with a poll that asks all the right questions and covers all the bases. Based on the results the majority of owners have not had an issue with this component. That is not what I expected to see based on previous comments / threads.
Old 02-11-2013, 11:02 AM
  #74
arrie
Simplify
arrie's Avatar
Location: forging ahead...making up for lost time and embracing each day thankful to be alive.... nj
St. Jude Donor '13-'14-'15
~~~ CFOT Book Folder ~~~
I have not had a problem but my car is a 2006 with 14K miles on it....
Old 02-11-2013, 11:23 AM
  #75
RobLo
RobLo's Avatar
I'm the second owner of my car, first owner was paralyzed (car had hand controls when I bought it) so I have to believe him when he said he never took the car over 70. I don't push the car, never been tracked, the occasional giddyap but I enjoy more the twisties that going fast in a straight line. Car has always been professionally maintained, my HB going (gone?) bad and about to be replaced at 22.5K pampered miles.
Old 02-11-2013, 12:19 PM
  #76
leng64
leng64's Avatar
GS 2011, replace HB at 1400 miles. I hope it will last me for many years to come. I currently have about 9500 miles. Still smiling.
Old 02-11-2013, 12:29 PM
  #77
Medic Man
Medic Man's Avatar
Seems like I see a lot of folks posting threads about the possible / failure of the harmonic balancer on their cars. I was curious in seeing just how pervasive the problem is. If you respond please indicate the mileage on your vehicle when / or each time you experienced the problem.
I have a 2012 GS, just had mine replaced with 2500 miles.. Kinda crazy this isn't a recall!
To Harmonic balancer failure poll
Old 02-12-2013, 09:54 AM
  #78
Chip A
Chip A's Avatar
It is crazy. Do you think it was chirping from day one?
Old 02-12-2013, 07:46 PM
  #79
B-Vette
B-Vette's Avatar
..I wonder if any of the people that voted have C-5’s as that also would skew the results. It is pretty hard to come up with a poll that asks all the right questions and covers all the bases...
No results to skew, many owners have had this type of problem starting on the C5 run and continuing with the C6. GM chose to go with the same type of balancer and roll the dice. Part should have been upgraded on the C6 but wasn't due to cost. Very painful for owners - almost as bad as the dreaded column lock issue.
Old 02-12-2013, 08:34 PM
  #80
TerryL
TerryL's Avatar
St. Jude Donor '17
I worry about what else it will destroy when it breaks and, what that will cost me...GM should really step up! Keeping fingers crossed at 58,000+ miles in my 06 vert.
Quick Reply: Harmonic balancer failure poll
