Adding NPP; The Electronics....
Old 02-09-2013, 06:52 PM
jensencl
jensencl's Avatar
Default Adding NPP; The Electronics....
Is it possible to add all the OEM electronics and vacuum line pieces and whatnot associated with the NPP mufflers rather than the M2W or Exhaust Commander from Sunset Orange Creations? I would like the OEM setup rather than an aftermarket setup.
Thanks in advance!
Old 02-09-2013, 07:10 PM
SunsetOrangeCreations
SunsetOrangeCreations's Avatar
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
You can run all the Oem lines and vacuum solenoid parts. That was how we originally did it back in 2007.
You will still need an aftermarket controller in order to operate the vacuum solenoid though.
Our Exhaust Commander Elite is a great choice because it has 3 operational modes.
1:Loud Mode
2:Quiet Mode
3: User RPM opening mode
So you can have a factory style operation with rpm opening, as well as the stealth quiet mode and loud mode.
Here is the thread for the controller:
http://forums.corvetteforum.com/c6-z...ck-button.html
Video of it in action:
If you need additional info, feel free to let us know.
Ben
Old 02-09-2013, 07:22 PM
jensencl
jensencl's Avatar
I have been weighing in the direction of yours since its the "most like stock" but with the M2W built in, and control using a button (I think its the reset button) from the DIC. I was just curious if adding the OEM parts was possible. Do you guys offer any forum pricing on your Exhaust Commander Elite unit?
Old 02-09-2013, 07:31 PM
St. Jude Donor '13
You can add all the Oem vacuum lines, the vacuum accumulator ball, and the vacuum solenoid. Then use an aftermarket controller to control it all.
It is very expensive to buy all the Oem stuff though. IIRC it was about $600 for all the lines, vacuum ball, and vacuum solenoid. And that doesn't include a way to control them.
Our Exhaust Commander Elite uses the door lock button on the door panel inside the car, and the cars keyfob remote when outside the car to control the system.
We also have the Exhaust Commander D.A.S.H. that uses the DIC reset button. It does not have RPM opening though. Just Loud or Quiet modes.
If you watch the video above it shows how everything works on the Exhaust Commander Elite.
We do have a sale on our Exhaust Commander Elite controllers. You would use coupon code "elite20" at checkout and get 20% off.
We two kits available.
One would be used if you have all the factory lines and solenoid. It is just the electronic controller.
The other is a retrofit kit which includes vacuum lines and a vacuum solenoid, and the controller.
Exhaust Commander Elite All-in-1 NPP retrofit kit
Old 02-09-2013, 07:39 PM
jensencl
jensencl's Avatar
E.C.E. All-in-1 NPP retrofit kit it is then. Thanks!
Old 02-09-2013, 07:43 PM
St. Jude Donor '13
That's great!
If you ever need any additional info, or help during your install, give us a call or send us a message right away.
We are always happy to help!
Ben
To Adding NPP; The Electronics....
Quick Reply: Adding NPP; The Electronics....
