Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-07-2013, 07:46 PM   #1
snaponjackson
CF Senior Member
Support Corvetteforum!
snaponjackson's Avatar
Default Go No GO Clutch... What do you do?
Just got my 2013 427 and it has that terrible go/no go clutch
pedal. My 2012 GS had the same thing. Any body have any
suggestions on a fix. I know you can install the ZR1 clutch, but thats a lot of work and money. Thanks for any good ideas out there.
Chris
snaponjackson is offline   Reply With Quote
Old 02-07-2013, 07:55 PM   #2
Pinky...
CF Senior Member
Pinky...'s Avatar
Drive it to wear the clutch in? Maybe some other members can chime in with their results but when I hear complaints of a touchy clutch, they are usually brand new and the friction material is still a little too grabby.
Pinky... is offline   Reply With Quote
Old 02-07-2013, 08:42 PM   #3
seamus2154
CF Senior Member
It takes many miles to properly break in a clutch. I have always found traffic can be your friend, after the motor break in, just to break in the clutch quicker. It does take a while, don't jump the gun. If your doing alot of highway miles in can take a long time to break in.
seamus2154 is offline   Reply With Quote
Old 02-07-2013, 08:45 PM   #4
AORoads
CF Senior Member
AORoads's Avatar
Maybe it's just my experience but I'd never heard of breaking in a street clutch until I got my '08 (non-Z06/non-427). I really do think it took awhile before it finally got settled in. Or maybe I just got settled in...to the clutch! In any event, I do agree with using it and the best place is in traffic to give it a lot of workout. Good luck with it.
AORoads is online now   Reply With Quote
Old 02-08-2013, 12:45 AM   #5
TKgs2010
CF Senior Member
Chris
I feel your pain, mine was the same way, but after about 1,000 miles it was just fine. Either I got used to it or it got used to me.
TKgs2010 is offline   Reply With Quote
Old 02-08-2013, 08:35 AM   #6
z51vett
CF Senior Member
z51vett's Avatar
Send a message via AIM to z51vett
Are we talking about the clutch causing car to shudder when engaging or something else. I've had 4 clutches replaced on Corvettes with less the 500 miles because of clutch shudder. One c6 z06 and one c5 98 and two c6s funny how the service writter wants the tech to drive it . David the Tech comes out I back car up so he can get in and he just turns around an goes to the parts dept to get the parts.
z51vett
z51vett is offline   Reply With Quote
Old 02-08-2013, 10:27 AM   #7
383vett
CF Senior Member
383vett's Avatar
You've got a 2012 and a 2013 with the same problem? Take them back to the dealer and have them fix both cars. Drive a couple of new cars off the lot and see if maybe you are expecting something different from what GM has to offer.
383vett is offline   Reply With Quote
Old 02-08-2013, 10:35 AM   #8
pmartjr
CF Senior Member
pmartjr's Avatar
Both mine and a good friend's 427 have what I would call senitive clutches. First thing I noticed was how low they engage. I questioned this at the dealer and was told they are all like that. I also had a little shudder and still do on occassion after 1700 miles. I have found that I just need to slip the clutch a little more than what you would expect but now quite used to it, so I consider it the nature of the beast.
pmartjr is offline   Reply With Quote
Old 02-08-2013, 03:01 PM   #9
a66bbvet
CF Senior Member
a66bbvet's Avatar
Are you sure it is the clutch and not the Traction Control? My 13 GS seems to have an issue and I find by turning off the TCS the issue is gone. The car will pull off like the old clutches and not seem to hold you back.
a66bbvet is offline   Reply With Quote
Old 02-08-2013, 03:36 PM   #10
z51vett
CF Senior Member
z51vett's Avatar
Quote:
It's not normal find a good dealer tech he will replace clutch for you.
See my post where I mention shudder in clutch I've owned 29 corvettes it ain't normal.
z51vett
Doug
Old 02-08-2013, 03:51 PM   #11
JJC5
CF Senior Member
JJC5's Avatar
The clutch shudder has been explained as a warped flywheel/pressure plate. It's been said that it frequently is caused by the the guy loading the car carrier and slipping the clutch so bad that it overheats and warps. My '07 did it since new and actually got a little better with time but it never went away. My Z06 has none of that shudder.
JJC5 is offline   Reply With Quote
Old 02-08-2013, 03:58 PM   #12
Al Gumby
CF Senior Member
Al Gumby's Avatar
Location: Hillsboro Oregon, I drive a lot in the freakin' rain.
Like many have reported here, when my `08 was new it had what has been described as a "quick clutch". I didn't like it and even stalled the engine a couple times, I hate that. But like the others, it broke-in, and it works very well now. Clutch chatter is a whole `nother matter.
Al Gumby is offline   Reply With Quote
Old 02-08-2013, 04:13 PM   #13
flange
CF Senior Member
St. Jude Donor '14
if a couple of spirited launches didnt fix it, it should go back to where it came from...
flange is offline   Reply With Quote
Old 02-08-2013, 04:21 PM   #14
hotinaztoo
CF Senior Member
hotinaztoo's Avatar
Default clutch shudder
Quote:
I cussed mine for 5 years, when a friend told me to turn off the Traction Control! It's now as smooth as my first 65 Vette!
hotinaztoo is offline   Reply With Quote
Reload this Page Go No GO Clutch... What do you do?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Hydraulic Clutch Conversion on a 68 4spd gc161968 C3 Tech/Performance 37 11-23-2013 07:35 PM
68 Needs a Clutch gc161968 C3 Tech/Performance 3 08-09-2013 07:39 PM
Going to sell the C6... SquareHead C6 Corvette General Discussion 19 05-06-2013 10:00 AM
Good replacement clutch? lt4obsesses C4 Tech/Performance 7 04-16-2013 07:06 PM
New Clutch snaponjackson C6 Tech/Performance 1 04-04-2013 05:51 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
