Help :/ Please....
3rd Gear
Help :/ Please....
Ok heres wat happen....i lost my fob remote key and i alrwady bought a new key and remote...how can i activate that key...i cant turn it on to take it to the dealership need help please
http://www.ls2.com/boggs/c6/C6%20Fob%20Programming.pdf
fyi.... if you have NO key that fits in the trunk, you are stuck. you must have a working key that fits in the trunk as step 1 , if you have no working key, a dealership must make it and you will have to show some proof before they will.
note: you are sort of confusing me. your said you got a new key and a new remote. your asking how to activate the key? do you want to know how to program the fob to the car or do you want to know how to have the key made to fit the trunk?
Two things, and I'm trying to be helpful here.
First, try to use a better title for your question like "How to program a fob?" or something like that. People won't know the problem if you just put "Help" for a thread title.
Second, try to use better spelling, English, and grammar. It is very difficult to understand your first post. After you write it, go back and read it again to make sure it clearly expresses your question. I have read it twice and I am not sure what you want.
I am not trying to be mean; I am trying to help you.
3rd Gear
here is a programming instructions. it shows how to add another one if you have 1 that already works. or what to do it you dont have any that currently works.
3rd Gear
I wrote these instructions to program fobs.
http://forums.corvetteforum.com/c6-c...tructions.html
If your metal key fits the trunk lock, then you should be able to program the new fob that you have. Read the instructions through before getting started. I would suggest starting with the short procedure so that you will have a fob that starts the car, then eventually you will have to do the long procedure to get things working correctly.
When the OP bought his '09 C6, I bet the dealer only gave him one fob&key. And he lost it.
So there's no way for him to program a new fob. And no way to drive the car.
A dealer can program a new fob. But I doubt your dealer makes house calls, so I don't know any alternative to a flat-bed tow.
