Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-05-2013, 02:55 PM   #1
Charles Jennings
Junior Member
Charles Jennings's Avatar
Send a message via Yahoo to Charles Jennings
Default 2009 Corvette C6 Coupe check engine code P0454
I used my code checker to find out why my check engine light came on. I tried to reset the check engine light with my code checker but the check engine light stays on and the code comes back when I restart the car. Its code P0454 Fuel tank pressure sensor. Is it hard to change? Anyone have any advice? 2009 Coupe 22000 miles.
Charles Jennings is offline   Reply With Quote
Old 02-05-2013, 03:01 PM   #2
Fiss
CF Senior Member
You cant just clear the code and not expect it to come back lol
Fiss is online now   Reply With Quote
Old 02-05-2013, 03:06 PM   #3
Charles Jennings
Junior Member
Quote:
I know that. I was asking is the fuel tank pressure sensor hard to change and has anyone else encountered this?
Old 02-05-2013, 03:44 PM   #4
ChevyDave
CF Senior Member
Support Corvetteforum!
ChevyDave's Avatar
p0454 is in the group of evap pressure codes.
i would replace the gas cap to eliminate that possibility. like most things, you replace the cheap first and since a new cap wouldnt hurt, good starting point.
fyi.. replace a fuel tank pressure sensor (if you get to that point)
Fuel Tank Pressure Sensor Replacement
Removal Procedure
Remove the right rear wheelhouse panel. Refer to Wheelhouse Liner Panel Replacement - Rear in Body Rear End.
Remove the evaporative emission (EVAP) canister access cover.
Disconnect the fuel tank pressure sensor electrical connector.
Remove the fuel tank pressure sensor by carefully prying the sensor out of the fuel tank with a screwdriver.
Installation Procedure
Lubricate the fuel tank pressure sensor rubber grommet with clean engine oil in order to aid in installation.
Install the fuel tank pressure sensor into the top of the fuel tank.
Connect the fuel tank pressure sensor electrical connector.
Install the EVAP canister access cover.
Install the right rear wheelhouse panel. Refer to Wheelhouse Liner Panel Replacement - Rear in Body Rear End.
ChevyDave is offline   Reply With Quote
Old 02-05-2013, 03:52 PM   #5
Charles Jennings
Junior Member
Yeah I kinda think this might be part of the cause because my gas cap doesnt seem to tighten as well. I will stop at the dealership and buy a cap today.
Old 02-05-2013, 04:02 PM   #6
Charles Jennings
Junior Member
Removal Procedure
AWESOME!!!!!!
Old 02-05-2013, 04:49 PM   #7
ChevyDave
CF Senior Member
ChevyDave's Avatar
if you want a good laugh...
cant say if sensor is bad, but here is some info if you end up needing it
gm part number 13502903 will look almost identical to this..
Click the image to open in full size.
see item #14..
http://store.gmpartshouse.com/parts/...gramCallOut=14
see item #1..
Old 02-06-2013, 02:26 PM   #8
Charles Jennings
Junior Member
Well the car is at the shop now the guy quoted me $90 labor to install the $70 part. I also purchased a new gas cap.
Old 02-06-2013, 02:52 PM   #9
CO Lightfoot
CF Senior Member
CO Lightfoot's Avatar
Quote:
New gas cap is cheap insurance & a good idea.
But I bet the fix you're getting involves R&R the evap canister Vent Solenoid... it's a logical next step... $90 + $70 sounds about right:
http://forums.corvetteforum.com/c6-c...49-w-pics.html
CO Lightfoot is offline   Reply With Quote
Old 02-06-2013, 03:04 PM   #10
Landru
CF Senior Member
Landru's Avatar
GM's lousy gas caps have struck me, only the DIC so stated a loose cap was at fault.
JMHO: if your problem's resolved for $160 +tx, feel fortunate.
As C6 repairs go, it's a bargain.
Landru is online now   Reply With Quote
Reload this Page 2009 Corvette C6 Coupe check engine code P0454
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
