What are shops charging to install lowering bolts
Old 02-04-2013, 01:04 AM
nitrouscharlie
nitrouscharlie's Avatar
Default What are shops charging to install lowering bolts
Working on a 2011 Grand Sport, and Im not in a position to do the work myself right now, so Im wondering what shops are charging to install lowering bolts on C6 Vettes.
Thanks Guys,
Charlie
Old 02-04-2013, 05:17 AM
MikeyTX
Support Corvetteforum!
MikeyTX's Avatar
Received 2,186 Likes on 1,337 Posts
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Post the question in the TX regional forum. Our rate in DFW is $90 hr
Old 02-04-2013, 05:28 AM
netacoma2003
netacoma2003's Avatar
I was quoted the same rate in the Seattle area. Only caveat was the shop had to buy the bolts, I could not bring bolts in (even if the package was unopened). They claim it's for liability purposes but obviously it's because they want to markup the bolts too.
Old 02-04-2013, 11:35 AM
FRChilln
FRChilln's Avatar
My local shop wanted $300. I laughed... Takes less then an hr to do.
Old 02-04-2013, 03:07 PM
Suzq
Suzq's Avatar
How low are you dropping it? My guy didn't take the bolts out, just adjusted down to them and it dropped almost an inch. Still paid too much ($50) plus realign ($50). Didn't want to have to stop for everything in fear of scraping. Cali has some crappy roads, already bent a wheel on the freeway!
Old 02-04-2013, 03:56 PM
Homer3D
Homer3D's Avatar
My local shop....
To install lowering bolts: $50
To just adjust the stock bolts to lower my car: Free
Old 02-04-2013, 08:37 PM
cmonkey713
cmonkey713's Avatar
Received 1,253 Likes on 916 Posts
If you want to drive it to Oklahoma City I will do it for you for free.
Old 02-05-2013, 11:39 PM
nitrouscharlie
Yeah, this all kills me since I normally do EVERYTHING myself, but Im not in a situation to do anything so Im at the mercy of my local shops. I paid one local shop to lower my Vette on stock bolts and you cant even tell they did anything. So I bought these lowering bolts and I want to just lower the rear another inch or so. I look like a damn 4X4 with expensive *** wheels.
Old 02-06-2013, 11:35 AM
jonathontodd
jonathontodd's Avatar
a jack, a jackstand, 10mm wrench, and about an hour....i wouldnt pay anybody more than $50 to do it.
Old 02-06-2013, 01:09 PM
LFZ
LFZ's Avatar
LOL...its a little more involved than that to install lowering bolts.
Old 02-06-2013, 01:57 PM
ls1121
ls1121's Avatar
St. Jude Donor '14-'15
OK this might be a stupid question but...with our cars sitting so close to the ground already why are you guy's lowering your cars?
Old 02-06-2013, 01:59 PM
Homer3D
Homer3D's Avatar
cause it looks better
Old 02-06-2013, 02:47 PM
Bedouin
Bedouin's Avatar
Charlie, if you're able to get under your car anytime soon, & you're front ride height is okay but only too high in the rear, I'd consider cutting 1/8" off the rear bushings instead of buying lowering bolts.
The bottom 1/8" metal plate (covered in rubber) cuts off easily (cable saw, or serrated blade w/ WD40) & reply if you need any instruction.
I've not run lowering bolts, but have read too many posts @ them wearing out early (metal on metal), squeaking, etc. Maybe someone will chime in w/ good reviews of the delrin versions, but I've not read that they last very long either.
You can buy a pair of like new OEM rear bushings on the forum & install them later if needed, & they do come up for sale albeit infrequently.
To What are shops charging to install lowering bolts
Quick Reply: What are shops charging to install lowering bolts
