Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-05-2013, 06:59 AM   #1
Patsgarage
Junior Member
Patsgarage's Avatar
Default 5th or 6th ?
What gear do you guys (and gals) use on the highway ? With the
3.42s in the rear 6th seems soooooo long at 70-80. 5th feels better, but is harder on the engine/trans etc. If only they would raise the speed limits, or better yet "left lane for Vettes only"
Patsgarage is offline   Reply With Quote
Old 02-05-2013, 07:05 AM   #2
C6Joy
CF Senior Member
Support Corvetteforum!
C6Joy's Avatar
On flat roads I would be in 6th. If it gets hilly or I need quicker response I will drop to 5th.
C6Joy is offline   Reply With Quote
Old 02-05-2013, 07:30 AM   #3
franman69
CF Senior Member
franman69's Avatar
I cruise at 70+ in 6th... Like C6Joy says, if it's hilly, I'll drop to 5th right away.
franman69 is offline   Reply With Quote
Old 02-05-2013, 07:36 AM   #4
Goatdad
CF Senior Member
St. Jude Donor '11-'12-'13
Goatdad's Avatar
use the correct gear for the situation.
Goatdad is offline   Reply With Quote
Old 02-05-2013, 07:52 AM   #5
Seadawg
CF Senior Member
Seadawg's Avatar
With the torque these vettes have, I use 6th for anything 55 mph and above, except when I'm wanting to really accellerate quickly.
I was recently in very steep "with truck lane" interstate VA and WV mountains, and I could easily hit triple digits while accellerating in 6th going UP the mountains. I was surprised how fast it would accellerate in 6th, going up those mountains.
And, going down the other side, the 6th torque would easily keep me from accellerating over the speed limit with the cruise control on.
Soooo, while 5th will not hurt the engine, 6th will get you better gas mileage, and will not hurt the car either.
Seadawg is offline   Reply With Quote
Old 02-05-2013, 08:02 AM   #6
Flh Den
CF Senior Member
Flh Den's Avatar
On the highway I am constantly shifting between 5th and 6th. When it feels like it's lugging a bit when I want to pass I go back to 5th, when I get around 60 or above on level roads I use 6th.
Flh Den is offline   Reply With Quote
Old 02-05-2013, 08:21 AM   #7
weathermaker
CF Senior Member
weathermaker's Avatar
6th most of the time if above 50mph.
weathermaker is offline   Reply With Quote
Old 02-05-2013, 08:42 AM   #8
alyupe11
CF Senior Member
alyupe11's Avatar
6th gear unless I'm looking for an adrenalin rush then its ?
alyupe11 is offline   Reply With Quote
Old 02-05-2013, 08:53 AM   #9
z51vett
CF Senior Member
z51vett's Avatar
Send a message via AIM to z51vett
I use 6th in town at 45 or above normal driving mines a z06 the 476lbs torque. I get around 20 mpg on highway 28. But if I start using 4th and 5th it goes down. On interstate use 6th unless traffic slows to below 45.
z51vett
z51vett is offline   Reply With Quote
Old 02-05-2013, 08:57 AM   #10
Sheep
Junior Member
6th on highway(anything over about 55). But i have forgot and left it in 5th for long distances with the windows down. As stated, lots of torque even in 6th.
Sheep is offline   Reply With Quote
Old 02-05-2013, 09:58 AM   #11
dvilin
CF Senior Member
dvilin's Avatar
Most of the time 6th gear if on the highway for a long period of time.
dvilin is offline   Reply With Quote
Old 02-05-2013, 10:05 AM   #12
JohnAE455
CF Senior Member
Use whatever gear feels best to you. Fifth is good from 30-180+ MPH. If the speed limit is 55 or above I use 6th and rarely need to shift down even to pass.
JohnAE455 is offline   Reply With Quote
Old 02-05-2013, 10:52 AM   #13
Wayne O
CF Senior Member
Wayne O's Avatar
"....5th feels better, but is harder on the engine/trans"
Why would you think that? If 5th gear feels better I think the opposite would be true. Going 70-80 mph in either 5th or 6th there isn't all that much difference in RPM's....RPM's are low in either gear. You can tell, if it feels like you're 'lugging' the engine in 6th don't use it. For me, 5th and 6th gears are strictly overdrive gears used for extended highway cruising....5th and 6th are never used for in-town driving. The principle is somewhat different for extended highway cruising in an overdrive gear but in general I always want to be geared in a reasonable power band. I guess everyone has their own style of driving but I don't understand those who deliberately skip-shift or use 5th or 6th gear driving 45 mph.
__________________
2005 Corvette C6 Coupe
Magnetic Red Metallic II/Cashmere, MN6, 1SB, F55
Lingenfelter 403 Conversion, LG Pro Headers (coated), Corsa Sport Exhaust, Lingenfelter CAI, Accusump, LGM Coil-Over Suspension & Bump-Steer Kit, T1 Sway Bars, Pfadt Control Arm Bushing Kit, Elite Eng. Tunnel Plate & Oil Catch-Can, SKF Racing Hubs/Bearings, AP Racing Brakes, DRM Brake Ducts, Custom Roll Bar, Sparco Seats, Wide-Booty, CCW C10 Wheels,
Setup: LG Motorsports
Thanks to: 21st Century Muscle Cars
Wayne O is offline   Reply With Quote
Old 02-05-2013, 10:58 AM   #14
not08crmanymore
CF Senior Member
not08crmanymore's Avatar
If you do a search there is a gear speed break down on this forum somewhere from way back.6TH is the cruising gear,that's why it's there.
not08crmanymore is offline   Reply With Quote
Old 02-05-2013, 11:01 AM   #15
ruxvette
CF Senior Member
Just like my underwear...depends. I have the MZ6 (Z51 package) so my 6th gear is 0.57 vs the standard 0.50...means I am a little higher rpm at speed. However, it still depends on speed, road conditions, etc.
ruxvette is offline   Reply With Quote
Old 02-05-2013, 11:21 AM   #16
peter pan
Life Time NCM #2196
peter pan's Avatar
Quote:
peter pan is offline   Reply With Quote
Old 02-05-2013, 11:36 AM   #17
jaki30
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12
Default For normal driving
I usually up shift out of any gear at 1,500 RPM and will downshift a gear if the RPMs drop below 1,000.
jaki30 is offline   Reply With Quote
Old 02-05-2013, 11:50 AM   #18
cclive
CF Senior Member
cclive's Avatar
Mine will go up the approaches to the Eisenhower tunnel in Colorado easily in 6th. This is the steepest section of Interstate highway in the country and required an exemption from the regular design standards to be built. Drive in whatever gear feels good to you, but don't think that the engine is lugging in 6th at 65 mph...it still has plenty of torque at that speed.
cclive is online now   Reply With Quote
Old 02-05-2013, 12:15 PM   #19
trading tiger
CF Senior Member
Owner's manual states for optimum fuel efficiency, shift out of:
1st @ 15mph
2nd @ 25mph
3rd @ 40mph
4th @ 45mph
5th @ 50mph
I might have those last 2 numbers wrong, they might be 50 and 55 respectively.
trading tiger is offline   Reply With Quote
Old 02-05-2013, 12:32 PM   #20
arrie
lover of all corvettes
arrie's Avatar
not a user
Send a message via AIM to arrie
I RARELY use 6th gear, unless I am cruising highway for an extended period of time. I prefer driving at slightly higher RPM's.....feels better to me. But hey, that's just me.
arrie is offline   Reply With Quote
Reload this Page 5th or 6th ?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
