Does Getting Headers Void Warranty?
I was just wondering if i got headers and had them installed by chevy will it ruin my warranty agreement? I have an exhaust all the way to the stock headers but i wanna change my stock headers to some B&B headers. If someone knows good headers list them in a comment below. Also i want loud headers (Loud exhaust system is music to my ears)
A lot of the voiding BS is how your local dealer handles things. The friendlier you are with/ how much business you have done with your dealer can make a BIG difference!
Also i have B&B x-pipe with no highflow cats, and a it goes into a bullet exhaust. Now the problem is if i get B&B long tube headers their are no cats anymore so does that mean its illegal to drive on the streets. Also what other headers hook up to my exhaust x-pipe that are good.
Also, a few issues with your original post. "Chevy" is not installing the headers are you suggested, the dealer is. Most dealers will do aftermarket type service like this however if you blow your engine, they will be unlikely to cover it under warranty. I would assume too, that you're getting tuned to see the real benefit of the headers so be sure you research your tuner and make sure he knows he's doing as a bad tune could easily lead to engine failure.
Federal felony....... I'm always amazed at how many people ignore the law.
CF Senior Member
IMHO there's no question about it.....adding long tube headers (with or without a tune) will void your power train warranty at the least. I know my local dealership takes that position. As mentioned, removing or altering the OEM cats is a violation of federal law except for offroad/track use. GM spends a lot of money engineering, building and providing warranty coverage on their vehicles. Any time you performance modify your car it is no longer the car GM engineered and built. My dealership aggressively denies warranty coverage for anything even remotely connected to a performance modification. I doubt any self-respecting dealership would remove the OEM cats, install long tube headers and say your full factory warranty is intact.
I suggest you contact the 'warranty' people at GM....explain to them you want to remove the factory cats and performance modify your car by adding long tube headers. Then ask if your full factory warranty will remain intact. I bet I know what they will say.
I'm all for performance modifying your car, however, if you're concerned about your warranty either wait until the warranty has expired or be willing to accept the financial consequences of your own actions...be willing to accept the loss of warranty coverage (or portions thereof). Again, if in-doubt contact GM and see what they say.
I agree and I'm fine with going against the law, since the law was only established to keep this country in order and create a better America. Also is it fine to install headers and not run a tune or without the tune it will ruin my engine/transmission.
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Magnuson-Moss Warranty Act
Peace
Chip
U.M.
In the people's communist state of California headers won't pass the visual inspection and thus fail SMOG even if it passes the sniffer test.
I plan to get around it. I just purchased a manifold and cat off of a C6 Z06 which should give the same power increase as headers.
So when the comrade at the SMOG station looks underneath the hood he will see a GM manifold and not be the wiser.
Interesting, the LS7 exhaust manifold has a header for each exhaust port in it.
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
course, OP did ask the question....so it looks like the verdic' is in---no agreement. you git to pick yer laws wif you're car. njoy!
Now with that said, headers will NOT cause any damage, it would be such a small impact on the engine that you're more likely to blow a valve if it's an LS7 than you are to cause engine failure because of the headers. The tune, possibly, I've seen a ton of bad tunes but mostly on boosted (turbo/supercharger) platforms that caused major engine failure, you'd have to pick a pretty big idiot to badly tune your LSx engine...
I honestly wouldn't bother worrying about the possibility of:
1. engine/powertrain failure
2. voided warranty claims
Buy the headers, get a proper tune (there's a dozen on this site, also Trifecta Performance is great for remote tunes).
Stingray Chevrolet installed my LG long tubes w/ LG hi-flow cat's. I was told by the owner, his son and on down that I have no cause to ever worry about a claim being denied because I have headers or their hi-flow cat counterparts. The service manager echoed the same sentiment. I agree wholeheartedly that most all of this decision is based solely on the dealership itself and the relationship they have with you, the customer. Now that I have headers I would NEVER drive a Vette than did not have headers.
Last edited by raspyc6; 02-05-2013 at 08:23 PM. Reason: because headers are the best mod ever
