How do i reset the window seal again?
I remember i had this issue once before and there was a simple fix. can anyone refresh me on how to get the windows to crack and uncrack properly upon opening and closing the doors on my Z?
Thanks.
Thanks.
Power Window Initialize
After a power reconnect such as
battery replacement, the window
indexing feature and the power
convertible top (if equipped) will not
function until the system is
initialized.
Once power is restored:
1. Close the doors.
2. Raise the window and hold the
switch up for three seconds after
the window is closed.
3. Release the switch, then hold
the switch up again for
three seconds and release.
1. Remember to do both windows.
2. You will need to do this every time the battery is disconnected for more than just a few seconds, then reconnected.
