Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-30-2013, 02:09 AM   #1
JLB768
CF Senior Member
JLB768's Avatar
Default Lowering Issue
Lowered my GS a few days ago, and cranked all four all the way counter-clockwise. I have a quarter inch difference between the front right, and front left, with the left side at 5" from bottom of the splitter, right at 5 1/4". Any idea why that would be?
JLB768 is offline   Reply With Quote
Old 01-30-2013, 02:24 AM   #2
switchblade six
CF Senior Member
switchblade six's Avatar
Have u put some miles on after?...may need to settle
Did u count the turns u put on each bolt...equal?
switchblade six is offline   Reply With Quote
Old 01-30-2013, 02:32 AM   #3
JLB768
CF Senior Member
JLB768's Avatar
Not a whole lot, been raining, and nasty here. I cranked them to their max, so counting wasn't a concern. I suppose I may need to let it settle more, and then re-adjust as needed. I should probably measure at the puck sites, instead of the splitter, now that I think of it.
Old 01-30-2013, 02:37 AM   #4
switchblade six
CF Senior Member
Rain here too...better than snow i guess
Yes and once you get her even dont forget to re align...
Old 01-30-2013, 02:42 AM   #5
JLB768
CF Senior Member
JLB768's Avatar
Yeah, only have about 100 miles on it, so no fear of tire wear yet. I'll get it realigned in the next month or so.
Old 01-30-2013, 08:07 AM   #6
LFZ
CF Senior Member
LFZ's Avatar
That's the way it is...too many variables makes it tough to have exact height on both sides when going equal turns. Not really a big deal...if it bothers you, raise the lower side up to accommodate.
LFZ is offline   Reply With Quote
Old 01-30-2013, 08:11 AM   #7
FortMorganAl
CF Senior Member
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MS,AL, or FL
Why not just adjust them the way you want them? Also realize that equal height at each corner does not mean equal weight and equal weight is a big factor in handling.
FortMorganAl is offline   Reply With Quote
Old 01-30-2013, 08:25 AM   #8
Justasheet
CF Senior Member
Justasheet's Avatar
Did you have someone else measure with you in it? Your weight could throw it off even more.
Jeff
Justasheet is offline   Reply With Quote
Old 01-30-2013, 09:47 AM   #9
haljensen
CF Senior Member
Support Corvetteforum!
haljensen's Avatar
Quote:
The reason is because you "cranked all four all the way" instead of turning each bolt an equal number of turns AND you are taking your measurements from exterior bolt on parts instead of the specific suspension parts the factory uses.
haljensen is offline   Reply With Quote
Old 01-30-2013, 10:23 AM   #10
Wayne O
CF Senior Member
Wayne O's Avatar
First, there's no guaranty your car was setup correctly from the factory and simply turning the bolts an equal number of turns (or all the way) is no guaranty the setup will be correct. Also, measuring off body panels isn't ideal either. I haven't done it with a stock suspension in a long time but there are specific steps and procedures to follow when adjusting the setup. This isn't complete but check tire pressures. Also note that the diameter of worn tires can differ quite-a-bit from side to side. You must also 'settle' the suspension before and during the measuring/adjusting process....and it is a process of measuring, adjusting, re-settling the suspension, measuring and adjusting again). It also helps immensely to have a dead level, drive-on lift to use....you want the car perfectly level when measuring and adjusting. Instead of measuring off of a body part or panel, try measuring off a hard point on the frame. I've often used what looks like an oval rivet head near to each of the oval frame slots on the frame (where jacking pucks go). These aren't subject to the variations of body panels. Frankly, with the stock suspension and measuring from a hard-point, a quarter inch variation may be the best you're going to get. Good luck!
__________________
2005 Corvette C6 Coupe
Magnetic Red Metallic II/Cashmere, MN6, 1SB, F55
Lingenfelter 403 Conversion, LG Pro Headers (coated), Corsa Sport Exhaust, Lingenfelter CAI, Accusump, LGM Coil-Over Suspension & Bump-Steer Kit, T1 Sway Bars, Pfadt Control Arm Bushing Kit, Elite Eng. Tunnel Plate & Oil Catch-Can, SKF Racing Hubs/Bearings, AP Racing Brakes, DRM Brake Ducts, Custom Roll Bar, Sparco Seats, Wide-Booty, CCW C10 Wheels,
Setup: LG Motorsports
Thanks to: 21st Century Muscle Cars
Wayne O is offline   Reply With Quote
Old 01-30-2013, 10:47 AM   #11
EyeMaster
CF Senior Member
miataracer
Quote:
In other words, did the job terribly and now things are not right.
Go somewhere that knows what they are doing, get it corner balanced as well as you can and get an alignment done.
EyeMaster is offline   Reply With Quote
Old 01-30-2013, 10:56 AM   #12
LFZ
CF Senior Member
LFZ's Avatar
You guys are funny....its not like its some sort of elaborate process. Lower and go....and corner balance on what I assume the OP has a fully street car...come on. BTW..you do not throw the alignment off that much when lowering on stock bolts, and if alignment was off..it was probably messed up from the start.
Old 01-30-2013, 11:20 AM   #13
haljensen
CF Senior Member
haljensen's Avatar
Quote:
It SHOULD be an elaborate process. The height and corner weights are set at assembly and changing the height changes wheel alignment and corner weight. Corner weight isn't important for street driving but alignment is important. Tires are expensive.
Old 01-30-2013, 11:27 AM   #14
JLB768
CF Senior Member
JLB768's Avatar
Terribly huh? I wonder if it was right from the factory, because we all know every Vette comes from the factory perfect, alignments on the spot, etc, right? I don't plan on racing the car, or taking it to it's top speed, it's a street car, I don't much care if it's so tight, that a bird s**t throws the balance off. It also aint my first Vette, I've lowered my previous three without wheels falling off, the engines exploding, or body parts melting. I was simply asking how each bolt being turned to the same end distance, could result in a quarter difference.
Old 01-30-2013, 11:29 AM   #15
shawn672
CF Senior Member
shawn672's Avatar
if you lowered all 4 all the way down and it doesn't sit even after a few miles, I would probably rejack it and make sure all 4 bolts are all the way down. Perhaps you didn't relieve quite enough stress off 1 of the sides so the bolt didn't go as low as the others? Just throwing out a guess here
shawn672 is offline   Reply With Quote
Old 01-30-2013, 11:30 AM   #16
JLB768
CF Senior Member
JLB768's Avatar
Not bothered, just curious. I'll drive it some, let it settle, and re-adjust as needed.
Old 01-30-2013, 11:33 AM   #17
LFZ
CF Senior Member
LFZ's Avatar
Static corner weights are not set at Bowling Green. Sounds like the OP is lowering his car for a better look.
Old 01-30-2013, 11:41 AM   #18
JLB768
CF Senior Member
JLB768's Avatar
Let me be a little more clear...I'm not complaining, or upset, I was simply asking a question about how bolts with the same number of threads, turned to their max, be it up/down, can have such a difference. I didn't do anything that can't be undone, and have destroyed nothing. I also mentioned in my second post, that I probably should have measured off the frame. No big deal, and no reason for some to be condescending. I've drive the car some, let it settle, re-adjust, let it settle, and when I feel I have it where I want it, I'll have it realigned. Not setting the car up for a nascar title run
Old 01-30-2013, 11:44 AM   #19
JLB768
CF Senior Member
JLB768's Avatar
Exactly, there was a huge gap between the fenders, and wheels, I was trying to narrow that some. Which I've done on my 08 Coupe, my 08 Z06, my 11 Coupe, and now this one.
Old 01-30-2013, 11:47 AM   #20
JLB768
CF Senior Member
JLB768's Avatar
Quote:
Appreciate it. And it could be my garage floor aint perfect either, who knows. You'd think some of these guys are crew chiefs, and you are f***ing with their title chase
Reload this Page Lowering Issue
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
