Skip Shift Eliminator catch-22
Old 01-12-2013, 11:16 AM
sxs191
sxs191's Avatar
Default Skip Shift Eliminator catch-22
I recently purchased and installed the skip shift eliminator for my 2013 GS. I took it for a test drive this morning and it seems to be working properly. However, I am now staring at the Malfunction Indicator Lamp on my dash. UGH! I read on a post after I purchased it that it doesn't work on the 13's but I figured I'd give it a try because the place I bought it from doesn't mention any issues with it on the 13's. Guess I have an issue.
Old 01-12-2013, 11:20 AM
HorsePower Junkie
HorsePower Junkie's Avatar
St. Jude Donor '20-'21-'22-'23
I wonder if you try the blown fuse trick will that work for you.
Old 01-12-2013, 11:31 AM
wteceraser
wteceraser's Avatar
I have the 2012 GS .Try the blown smart fuse .Worked like a charm for me and get your money back on the Eliminator and save 16 bucks .
Old 01-12-2013, 11:33 AM
BearZ06
BearZ06's Avatar
Received 1,347 Likes on 778 Posts
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
Blown fuse works on my 13.
Old 01-12-2013, 01:52 PM
kp
kp's Avatar
Blown smart fuse working fine on my '12 as well.
I cant see what they would have done to the 13's just to change how the CAGS works for the last year of production. I would make sure it its plugged in all the way or it may just be bad.
Old 01-12-2013, 02:09 PM
carpe dm
carpe dm's Avatar
Which fuse?
Old 01-12-2013, 02:17 PM
wteceraser
wteceraser's Avatar
number 10 in fuse box in engine compartment .
Old 01-12-2013, 02:35 PM
STEVE MC
STEVE MC's Avatar
I don't get it...............why do you need to pay for a skip shift eliminator. It's the biggest rip off going.
You can opt for the fuse solution or just shift to 3rd instead of 4th.
Both my Vettes are 6 speeds and I never had a problem.
Most of the time I'm reving high enough to avoid the skip, but in real slow moving traffic shifting to 3rd is easy enough. These engines have so much tourqe it's like going from 1st to 2nd in a normal car.
Old 01-12-2013, 02:38 PM
1BADLS3
1BADLS3's Avatar
Mine is tuned out. No skip-shift or dash lights.
Old 01-12-2013, 03:27 PM
big duffer
big duffer's Avatar
We dont get many days like this... Hope you enjoyed it.
Old 01-13-2013, 06:40 PM
Patsgarage
Patsgarage's Avatar
Received 1,596 Likes on 1,074 Posts
Where did you get your kit from ? i got mine from SLP in NJ for my 13 GS and have had no problems in almost 2k miles. The 1>4 light still comes on, but no mil light.
Old 01-29-2013, 05:33 PM
timmyZ06
timmyZ06's Avatar
whats the blown fuse trick?? i heard that if you take out the fuse mil come on
Old 01-29-2013, 05:44 PM
TLS_Addict
TLS_Addict's Avatar
Use more right foot.....no more issue.
Old 01-29-2013, 06:31 PM
truth.b
truth.b's Avatar
Default smart fuse
I can say the Smart Fuse mod does work on a 2013 Grand Sport. I purchased a couple of 10A minis from O'Rilleys for $6 and I haven't had an issue yet. I used my motorcycle battery to blow the fuse. And I still get the dash light but the lock-out doesn't engage.
Smart Fuse:
Old 01-29-2013, 06:38 PM
Homer3D
Homer3D's Avatar
Excuse me if I am being a little ignorant.
I understand that if you pull the fuse out for the skip shift, it will stop it from engaging but it will also cause the check engine light to turn on.
But can someone explain to me why a blown smart fuse can trick the skip shift from engaging without causing the CEL versus a blown regular fuse?
Old 01-29-2013, 06:44 PM
JJC5
JJC5's Avatar
I believe it only allows enough current to light the LED on the fuse when it's blown which in turn makes a complete circuit but with such a small amp draw that the device it's connected to doesn't function.
I don't quite understand why the Skip Shift Eliminator isn't doing it's job with the CEL though.
Old 01-29-2013, 07:31 PM
o_town_racer
o_town_racer's Avatar
Blown smart-fuse worked for my 2011 GS
To Skip Shift Eliminator catch-22
Old 01-29-2013, 08:09 PM
shawn672
shawn672's Avatar
Get a tune and have them flash it out...
Old 01-29-2013, 08:16 PM
HorsePower Junkie
Get a tune and goodbye GM warranty.
Old 01-29-2013, 09:05 PM
Boomer111
Boomer111's Avatar
Fine with me, my C6 was tuned with 800 miles on the odometer.
The 5 year warranty just ended with no need for it too.
Quick Reply: Skip Shift Eliminator catch-22
