low beam alignment
low beam alignment
Quick question for anyone who has installed the 6000k HID low beams. Do these need to be aligned, or is the assembly setup to just plug the bulb in and it is lined up straight? Concerned about one being a bit off from the other side.
If your headlights were aimed correctly in the first place, you shouldn't have touch anything.
However, if you want to aim them, here's how..........
