Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-22-2013, 11:45 PM   #1
C5-JIM
CF Senior Member
Support Corvetteforum!
C5-JIM's Avatar
Send a message via AIM to C5-JIM
Default 2013 exaust
I just bought a 2013 vette and it apears to have either 4 cats or 4 mufflers and 2 cats. What are they ? I dare not to say which coupe I bought.
C5-JIM
C5-JIM is offline   Reply With Quote
Old 01-23-2013, 01:14 AM   #2
ELP_JC
CF Senior Member
Your car is identical to a 2011, except 2 small cats were added to the 'X' pipe to comply with CA emissions, for a total of 4 cats (the main ones are much larger). And there're only 2 mufflers at the back. Anyway, since I don't live in CA, I swapped my '12 GS X-pipe (same as yours) with a '11 GS one. Mostly to reduce the already ridiculous heat under the tunnel. It worked, but it was still more than I wanted in the TX heat, so insulated the tunnel as well. Both have identical dimensions, and as I said, the cars are identical underneath. And yes, the NPP sounds nicer in loud mode now, which I use most of the time. Below is a pic with the difference; hope it helps man. Good luck.
Click the image to open in full size.
ELP_JC is offline   Reply With Quote
Old 01-23-2013, 02:12 AM   #3
AddisonD
CF Senior Member
AddisonD's Avatar
How do you get the NPP exhaust to stay in the loud mode?
AddisonD is offline   Reply With Quote
Old 01-23-2013, 05:45 AM   #4
steve8
CF Senior Member
steve8's Avatar
Quote:
Pull the fuse or buy the controller.
steve8 is offline   Reply With Quote
Old 01-23-2013, 08:05 AM   #5
AddisonD
CF Senior Member
AddisonD's Avatar
ELP JC, I think you are saying there were 3 "things" on each side in 2013, but not in 2011. The pipe on the left in the picture shows two "chambers" near the end of the pipe runs, one on each side, which I assume are the cats. If there are two mufflers after that, that totals 4 "chambers". But the OP is seeking to identify 6 chambers. Would there be 2 more chambers after that one pictured, with the final one being the muffler?
steve8, thank you for the reply. That's a reference to a 3rd-party aftermarket controller, right? Chevrolet does not make such an accessory, do they? Would such a controller impact the validity of the warranty? Do you remove the whole device prior to taking the car in for a service call?
Thanks.
Old 01-23-2013, 08:33 AM   #6
Joe B.
CF Senior Member
Joe B.'s Avatar
So the stock 2011 X pipe is a drop in on the '12 and '13? No tuning issues? That is good to know as this article implies some fitment issues when using aftermarket exhaust. http://www.corvettenewsblog.com/2012...ic-converters/ The other cats are in the down pipe.
Joe B. is offline   Reply With Quote
Old 01-23-2013, 08:33 AM   #7
LS3 MN6
CF Senior Member
LS3 MN6's Avatar
I did not know CA added those extra resonators. CARB strikes again.
LS3 MN6 is offline   Reply With Quote
Old 01-23-2013, 08:38 AM   #8
Joe B.
CF Senior Member
Joe B.'s Avatar
Quote:
They are on all the cars AFAIK. Mine has them.
Old 01-23-2013, 08:59 AM   #9
z51vett
CF Senior Member
z51vett's Avatar
Send a message via AIM to z51vett
My 2012 z06 has this as well 4 cats couldn't believe it.
z51vett
z51vett is offline   Reply With Quote
Old 01-23-2013, 09:03 AM   #10
rcwsound
CF Member
rcwsound's Avatar
Thanks.[/QUOTE] Yes on 3rd-party http://forums.corvetteforum.com/c6-c...ld-switch.html
Don't know about warranty, but yes just remove it.
rcwsound is offline   Reply With Quote
Old 01-23-2013, 09:26 AM   #11
steve8
CF Senior Member
steve8's Avatar
Thanks.
pm sent.
Old 01-23-2013, 09:28 AM   #12
capecodvette
CF Senior Member
to the best of my knowledge....3rd party M2W systems do not void the factory warranty. Dealers actually install them for customers.
I purchased the Exhaust Commander Elite through SunsetOrangeCreations. Ben, the owner is awesome, as is the system. Love NPP loud, and the ability to switch back and forth.
__________________
CapeCodVette
USN (1971-76)
2013 Gran Sport Convertible
3LT
NRB, Blue Top, 2-tone Titanium/Gray/crossed flags
Mag Selective Ride Control
NPP
Automatic
Red Calipers
ZR-1 spoiler
Chrome Wheels
Battery protection
Corvette stainless pedal covers
capecodvette is offline   Reply With Quote
Old 01-23-2013, 11:48 AM   #13
truth.b
CF Senior Member
truth.b's Avatar
truth_brown
I have an Exhaust Commander Elite through SunsetOrangeCreations as well and to me its a sweet setup. I use the User setting with the valves opening at 2400 RPM and closing at 1500 RPM, it a good mix between acceleration and cruising.
truth.b is offline   Reply With Quote
Old 01-23-2013, 11:57 AM   #14
capecodvette
CF Senior Member
Quote:
Hello Truthb. Does your M2W setup work off both of the Key Fobs, and including the door lock/unlock switch, and visor buttons?
__________________
CapeCodVette
USN (1971-76)
3LT
NPP
Automatic
Red Calipers
ZR-1 spoiler
Chrome Wheels
Battery protection
Old 01-23-2013, 12:17 PM   #15
MikeyTX
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
MikeyTX's Avatar
Those are small resonators similar to what Corsa has on their touring exhaust. I had a set installed on my '11 w/o issue. I can now run in 6th on the highway w/o cabin drone.
__________________
Can't see my sig picture ? That's because the Vette is white .............. And I took the picture in a blinding snow storm........................ ..............
MikeyTX is offline   Reply With Quote
Old 01-23-2013, 02:02 PM   #16
Mike's LS3
CF Senior Member
Mike's LS3's Avatar
Thanks.
On the 4 cat exhaust systems, there is one cat attached to the exhaust manifold not shown in the picture. So yes, 2 cats and one muffler per side.
Mike's LS3 is offline   Reply With Quote
Old 01-23-2013, 02:05 PM   #17
johnodrake
Moderator
johnodrake's Avatar
Johnodrake @CdrDrake johnodrake
I would think that is correct. My M2W was installed at the Corvette Museum when I picked it up.
__________________
Vita contin git. Vive com eo!
60th Anniversary 427 CE - Bone Stock.
MSM '06 415ci LS3 510rwhp, RPS, DeWitts, Pfadt Coilovers, MGW. Full 2012 GS body and interior conversion C6Z Exhaust
Leather by DSV
Powdercoating by Mike
DD 05 Silverado Z71
'89 Coupe - for Brody
Spring Mountain x4
Gone now but not forgotten:
Sebring Silver '97 LPE SC
Mille Miglia Red '73 L82 Coupe
Daytona Yellow '70 L46 Coupe
johnodrake is offline   Reply With Quote
Old 01-23-2013, 02:11 PM   #18
Mike's LS3
CF Senior Member
Mike's LS3's Avatar
Quote:
z51vett
Thanks to the EPA, more weight and more costs. The EPA is bringing up the cost of goods in this country and reaching in our pockets. For those who respond "it's better for the environment" LOL. IT'S A BUSINESS!!!
Old 01-23-2013, 10:19 PM   #19
truth.b
CF Senior Member
truth.b's Avatar
truth_brown
Short answer is Yes it does, but my car is a 2LT so I don't have buttons on my visor.
Long Answer:
My setup isn't as simple as the M2W closed or open system. My system has 3 settings (listed below) and pressing the lock button on either door or key fob will cycle the system through the 3 settings. Lastly, the controller will remain in which ever setting it is left in when the car is turned off.
Settings:
1: Quiet --> factory NPP setting open/closed at around 3600 RPM.
2: Loud --> open valves at all times.
3: User --> Personal choice of when to open and closed. Open@2400RPM and Closed@1500 RPM.
Old 01-23-2013, 10:35 PM   #20
Rob 99
I'm "Apache" a psycho dog
Rob 99's Avatar
Are there any o2's connected to those cats?
Did you notice any change to the exhaust note/tone?
Rob 99 is offline   Reply With Quote
Reload this Page 2013 exaust
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
