Tail Lamp bulb replacement
Old 01-15-2013, 10:59 AM
xgto
xgto's Avatar
Default Tail Lamp bulb replacement
Has anyone tried these led replacement bulbs ?
Pilot Automotive Light Bulbs LI-3057
Last edited by johnodrake; 01-15-2013 at 11:07 AM. Reason: Non Supporting Vendor Link removed
Old 01-15-2013, 11:00 AM
bucwheat
bucwheat's Avatar
I had a set in my C5 and made the lights blink really fast.
Old 01-15-2013, 11:24 AM
vig1116
vig1116's Avatar
plus, if you look at the reviews on amazon, they all say too dim to see by others...
Old 01-15-2013, 12:38 PM
EVRose
EVRose's Avatar
I had them in my previous car and took them out immediately. Not even close to being enough light to be seen in the day time and I had clear lenses on that car too.
Old 01-15-2013, 06:41 PM
acesx4
acesx4's Avatar
Just purchased LED's tail lights.... took care of that!!
Old 01-16-2013, 12:35 AM
Knob Jockey
Support Corvetteforum!
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
For the tail lights, if you want a LED "bulb" to replace the OEM, check out the V-Star from V-LED's.
As with any LED turn signal, you have to include load resistors to eliminate the hyper-flashing.
Old 01-16-2013, 03:20 PM
MTsVette
MTsVette's Avatar
Location: O'Fallon Illinois - Currently own a 2016 Z06 1LZ A8 Coupe
Your 2nd point is why I'll stay with the OEM bulbs...don't fix what ain't broke...
MT
Old 01-17-2013, 01:28 AM
Knob Jockey
MT- You're absolutely right, this mod isn't for everyone.
But IMHO it's worth the effort because the LED's are much brighter, they are virtually indestructible, and at freeway speeds, they come on so fast that following drivers will have more time to react (there's an equation somewhere that quantifies the actual distances, and it's significant).
Load resistors are kinda like normal light bulbs but they don't light up, they just generate heat.
None of this adversely affects reliability and based on the large number of positive posts about the Eagle Eyes tail lights, it seems like a good upgrade.
Of course YMMV.
Old 01-17-2013, 02:10 AM
JCtx
JCtx's Avatar
I also want to add LED bulbs for the taillights and for the front turn-signal/DRLs. But I don't want any resistors, and certainly don't want to change the taillights; I like them.
I recently started a thread over the tech section, but nobody replied. Found 3157 bulbs (what we need) that are CANbus compatible, but they don't guarantee to stop hyperflashing. They cost $20 a pop, so too expensive to experiment with. Found them at superbrightleds, but can't link them or the gestapo would come after me . Just search for '3157 CANbus LEDs' and there's just one such bulb. And it's rated as some of the brightest, with 360º visibility, so it should be at least equal to the stock incandescent bulbs. And it's offered in white, amber, and red. If you feel like experimenting OP, do it for the gang and report back to us .
Old 01-17-2013, 12:34 PM
FLZapped
FLZapped's Avatar
MT
Except that Chevy's design for the DRL is broken. The lamps melt the housing over time.
Old 01-17-2013, 04:24 PM
LS WON
LS WON's Avatar
MT
hyper flash
Old 03-27-2015, 09:19 PM
hrgottlieb
8th Gear
hrgottlieb's Avatar
How do I replace tail light bulb 2007
Old 03-27-2015, 09:39 PM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
There's one screw at the top of the lens that you have to remove ... that's all. Then take the complete light out and change the bulb. I think it's a Torx 15 screw.
I just took mine out a couple of days ago to clean some of the gunk off the bottom. It's about the easiest thing you can change on a Vette.
Old 03-27-2015, 09:43 PM
NVR LAT
NVR LAT's Avatar
Just my opinion, but I replaced my tail light and front driving lights with LED's. I tried some of the cheaper ones, but ended up spending the money and buying CREE LED's. They are well worth the extra money. Unfortunately I got rid of my '05 and just got a '12 Grand Sport. I have just placed another order for all exterior CREE LED's once again. They're a bit more pricey than a lot of the bulbs out there, but I guarantee you won't be disappointed. Of course, you will have to add the resistors for any bulb that blinks to stop the "hyper flash". I think Radio Flyer is a sponsor here on the forum...that's where I got my bulbs. They are very good to deal with, they were for me anyway...Good Luck, you will love the end result.
Again, just my opinion...Just replacing the bulbs with a good quality one, looks better that replacing the whole light fixture. The stock C6 tail light is a beautiful thing. Replacing the the complete light fixture changes the tail light look completely. Of course, this is a preference only, obviously there are people that prefer the "eagle eye" look as well. It's up to you...
Old 03-28-2015, 03:06 AM
Dano523
Dano523's Avatar
Received 3,020 Likes on 2,175 Posts
Not if you use Dielectric grease in the sockets.
Also a little trick if you keep burning out your front turn signal bulbs/they will not work even when the bulbs are still good. On the left hand side in the socket (wires straight up out of the top), use a pick tool and bend the small tab outwards on the socket so they makes clean contact to the wire on the bulb's tumbstone.
Look at this socket in the middle photor, and notice that the two small side prongs on the right hand side that need to connect to the bulbs tombstone wires (socket upside down that you will be looking at it on the car), and see that they are recessed back and will not make a strong contact to the bulb tombstone connector wires.
Just use a pick tool to bend them back outwards toward the center of the tombstone channel, then use Dielectric grease in the sockets to keep the connectors clean and diffuse the heat of the bulb.
corrado (04-13-2016)
Old 03-28-2015, 10:23 AM
jovette
jovette's Avatar
Great Post by Dano 523 above. Good job
To Tail Lamp bulb replacement
Quick Reply: Tail Lamp bulb replacement
