Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-07-2013, 07:37 AM   #1
1bdvet
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
1bdvet's Avatar
Default 2005 Battery replacement
I know this must of been brought up, but don't remember it.
I have this item you plug into cigarette lighter to hold all the memories so you don't loose setting when replacing battery, does it work on C6.
Has anybody used this with success or I'm wasting my time.
Click the image to open in full size.
1bdvet is online now   Reply With Quote
Old 01-07-2013, 07:47 AM   #2
Gman in NC
CF Senior Member
Gman in NC's Avatar
I think the only thing you will lose is the window indexing. I didn't use anything on my 05.
Gman in NC is offline   Reply With Quote
Old 01-07-2013, 08:25 AM   #3
weathermaker
CF Senior Member
weathermaker's Avatar
If you got it, why not use it? I would not go out and buy one though. As stated only window index needed.
weathermaker is offline   Reply With Quote
Old 01-07-2013, 08:25 AM   #4
Top_Fuel
CF Senior Member
Top_Fuel's Avatar
Quote:
I use one of those every time I remove battery power from any car. My wife really gets annoyed when her radio pre-sets and clock time disappear.
Here is a set of basic instructions if you aren't sure how to use it. You can buy these things on Amazon for under $10. It's just a good practice to follow...especially if you wrench on other people's cars. Just make sure the lighter socket you are using has power even when the car is off (I'm not sure how the socket works on a C6).
Top_Fuel is offline   Reply With Quote
Old 01-07-2013, 09:29 AM   #5
EVRose
CF Senior Member
EVRose's Avatar
Quote:
Same here.
EVRose is offline   Reply With Quote
Old 01-07-2013, 09:33 AM   #6
1bdvet
CF Senior Member
1bdvet's Avatar
Quote:
The picture is the one I had for years, then I started buying cars with no cigarette lighter, so was toss in draw till now.
Old 01-07-2013, 01:59 PM   #7
Dave S
CF Senior Member
Support Corvetteforum!
Dave S's Avatar
Replaced the battery in my '05 last year without doing anything special & did not lose any settings, including the window indexing. Just get the new battery connected without too much delay.....took me less than 5 minutes.
Dave S is offline   Reply With Quote
Old 01-07-2013, 06:19 PM   #8
Gman in NC
CF Senior Member
Gman in NC's Avatar
I had my battery out for about 24 hours. Took the old one when I picked up the new one and trickle charged it overnight before putting it in. Never lost anything including the oil life indicator, radio presets, trip millage or anything.
Old 01-07-2013, 07:56 PM   #9
VET4LES
CF Senior Member
VET4LES's Avatar
It takes about 10 seconds to index the windows.
VET4LES is offline   Reply With Quote
Old 01-07-2013, 08:32 PM   #10
coolou
Junior Member
Actually I am not sure what type of battery I have in my 2007 Corvette Coupe but when I had a 2003 Corvette Convertible the water in the battery boiled out because the battery tender must have overcharged over the Winter so I replaced the water with distilled water used in steam irons and put it on a short charge and it came back to life.
It surprised me that the battery wasn't totally sealed and I could replace water in it just like I did on some of my old 60's cars
coolou is offline   Reply With Quote
Old 01-07-2013, 09:12 PM   #11
CO Lightfoot
CF Senior Member
CO Lightfoot's Avatar
For your 2005 C6, make sure you get:
-- the right size battery and
-- the correct post orientation
2005, 2008 and 2009 use the same-size battery tray. 2006 and 2007 models use a different tray.
2005 use batteries with the positive post on passenger side of the battery. 2006-2009 cars use batteries with the positive post on the driver side of the battery (also called "reverse" post).
More tips:
http://forums.corvetteforum.com/c6-t...rocedures.html
More details:
http://forums.corvetteforum.com/c6-t...-c6-coupe.html
CO Lightfoot is offline   Reply With Quote
Old 01-07-2013, 09:34 PM   #12
1bdvet
CF Senior Member
1bdvet's Avatar
More tips:
More details:
Thanks for Info!
Old 01-08-2013, 08:44 AM   #13
dcarter0001
CF Senior Member
dcarter0001's Avatar
Wouldn't a battery tender with a lighter attachment do the same thing?
dcarter0001 is offline   Reply With Quote
Old 01-08-2013, 09:28 AM   #14
CO Lightfoot
CF Senior Member
Quote:
Interesting.
Very easy to test it -- if I still had a C6.
Old 01-08-2013, 03:17 PM   #15
victorf
CF Senior Member
victorf's Avatar
For those that claimed disconnecting battery and not loosing anything - certainly, you guys are the lucky one with the magic Corvette from GM! Probably you also have one of those freak built engine that has more power than the rest of us mortals.
I am one of the unlucky few that suffer loosing window indexing and current time set with my radio - every time - no matter how fast I made the disconnect/reconnect - I get it - my car never came with one of those invisible permanent battery connection.
So, in panic, I did these in hope of making up by not having one of those invisible connection:-
http://i896.photobucket.com/albums/a...6/P1010006.jpg
So full of these unsubstantiated wild claims on the Forum.
Another good laught for the day!!!
victorf is offline   Reply With Quote
Reload this Page 2005 Battery replacement
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
