is the blendmount the only decent detector mount?
I like it. I never considered buying a detector until I saw the blend mount.
Yes its a little pricey, about $150 when you get the power cord and S&H but its made extremely well, fits perfectly, no shake ,doesnt move, clean install.
I wish I had found it 10 years ago.
Just Do It !
Just Do It !
Gotta say I thought it was pricy as well, but it's money well spent. It mounts the radar in a good place, and the mirror tap works great as well. You can take it off the mount if you go somewhere that they are not allowed, such as a military base.
-Bob George
-Bob George
Received 2,047 Likes
St. Jude Donor '13
A friend took the suction cup mount for his Valentine; removed the cups, turned it around, and mounted it into the plastic w/s trim with small sheet metal screws and small rubber grommets that allow mating the flat surface of the mount onto the curved w/s trim.
It sits about where the Onstar box would be if he had it. Semi-stealth, and the Valentine remote indicator on the steering column.
I removed my Onstar box (lost only the Onstar, nothing else) and put mine in the same place. Love it.
I may end up getting a blendmount, right now mines mounted up high to the right of rearview just below the XM box, using the suction cups and a smartwire. Its a Beltronics Pro RX-65, in stealth mode.
My biggest concern with the Blendmount is, if I am stopped with the Blendmount....the RD will be the first thing a cop sees when he walks up to the car. At that point, not much chance of him just giving a warning.
Bert
Roll Tide!
Bert
Roll Tide!
After the tape came loose on the GL for the 2nd time I broke down and bought the Blend Mount. I thought it seemed expensive too. But, guess what, my detector is always pointing the correct direction and the mount has never came loose. You definitely get what you pay for. I would buy one again if I had it to do over.
I'll admit that installing the Blend Mount is a little odd and the instructions aren't quite as clear as they could be but once you have it installed, you're done.
Good luck!
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Bought it - love the fit/finish...well worth the money IMO. If anyone is interested, I've got the Great Lakes visor mount with Invisi-cord available for $20. Drop me a pm.
St. Jude Donor '13
We had a 2006 without Onstar, first day in the 2009 she said "what's that big ugly box by my head?"
Not as far as I am concerned...here's mine. I like the location much better. I have my Redline on it now...the pics show my 8500 X50.
http://forums.corvetteforum.com/c6-c...nt-w-pics.html
it does not block visibility..looks that way from pic..but its up hi by my rear view mirror..when if warns me..i can check out front and in my mirror quickly..
