Display indications
Display indications
I'm not sure if I asked this question before but.....
I was wondering about this. I have an 2007 C6 with only 13,700 mi on it and now I'm getting a display reading that shows Check oil level. This all started just a few miles after I had the oil changed .
I checked the level and it was fine, so took it back to the dealer and they said, "Its most likely the gauge cluster, or the sending unit at the tank". They went on to say, "It's not a big deal at all, as long as the level is fine". Is that true?
Also, do you think it would help or fix the problem if I just reset the switch back to 100% and let it count down from there?
I've only put a 150 miles or so on it since this started.
Can I get some opinions?
I don't have any suggestions for fixing the problem other than: don't set the oil life left gauge back to 100%. For sure, that won't fix it, and it might cause you to not change the oil when it should be.
I kind of figured that but just thought I'd throw it out there. As far as the oil life is concerned that wouldn't matter too much because the car hasn't been driven that much since the oil change.
Any other thoughts??? Thanks again in advance.
And no, it really doesn't matter about the level as long as you aren't using any oil. But the sensor also reads oil temp used to set the oil life usage.
