key fobs
1 Post
key fobs
I have a 2010 vette. I had to buy new fobs 1 and 2. Right now I start the car with key in glove box fob 2. When I reprogram the new ones will my info come up for them ? Thanks
https://www.corvetteforum.com/forums...tructions.html
Read these instructions fully before starting. If you have to use the glovebox slot now, it means the fob is properly programmed but has no battery power.
Fobs don't become magically unprogrammed.
OP: Why did you need to buy two new fobs?
1 Post
The first fob my daughter ran over after it came apart on my husbands key ring. The other one fell behind my seat and was crushed and never worked right after that. It would never recognize a fob so I put it in the glove box. I have now bought the rubber fob covering so they can't come apart.
1 Post
I have read the long and short programming instructions. Just want to make sure I am understanding them correctly. I have 1 orginal fob not being recognized by the car so I use the glove box slot to start the car so I know the glove box slot works. I bought 2 used fobs 1 and 2. I want to reprogram these and get rid of the non working one in glove box. So I can use long programming steps 11-22 to erase the 2 used fobs I bought memory and reprogram to my car and info. Correct ? Thanks
You will start with step 11, but do not ignore all the previous instructions also...a battery tender or charger on the battery is important for example, as stated in the first paragraph.
1 Post
Successful !
So proud of myself ! I hooked up the battery charger. I had to take off the one side of my back up camera so the key trunk would turn all the way. I programmed both remotes and everything works ! The dealer wanted $180.00, locksmiths $100.00 plus ! Thanks everyone. I printed the instructions and followed the long one. Now both remotes are in the rubber cover so they can't come apart !
Received 1,136 Likes
1 Post
http://ww2w.corvetteforum.com/forums/c6-corvette-general-discussion/2452911-c6-comprehensive-fob-programming-instructions.html
