CAGS Elim. Fuse ??
Location: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Received 1,142 Likes
CAGS Elim. Fuse ??
I understand it will not work on The 2013 Model but does it work on The 2012 Model ??
I have a 2013 427 and the blown fuse is working for me. Sorry, can't answer for 2012 but go to NAPA and get a couple of smart fuses, direct connect across the battery so they blow, then install and see if it works. Should cost you about $3 to experiment.
please explain to a CAGS newbie!
Sorry, I don't mean to hijack - CAGS defeat is something I would like to do, but am not up to speed yet. (pun intended). Is the fuse you are referring to in lieu of the CAGS wiring harness defeat - or do you still need to get under the car and install the wiring harness defeat? And, when this is done, does the 1-4 shift light go away for good??
Thanks in advance...
