new car Noise in dash
Old 12-04-2012, 08:31 PM
hydrasport
hydrasport's Avatar
Default new car Noise in dash
I have a C5 Z06 and a new C6 base with about 60 miles on it. The C5 is solid and has no noises other than standard road noise (and a great exhaust rumble). The C6 has a very quiet ride but it has a buzzing or vibrating noise that sounds like it is in the center of the dash and below the bottom of the windshield. It starts at about 70 mph and gets louder and faster as the speed of the car increases. Happens with ac on or off and sounds almost like a leaf in the blower motor but it is related to vehicle speed. No way this is normal as it can get as loud as the normal volume of the radio. Before I take it back to the dealer, I was wondering if any one has experienced the same type of issue with their C6. It will be a few days before I get the car to the dealer and I'm just asking if any one has ran across this problem before.
Old 12-04-2012, 08:41 PM
Ike Witt
Ike Witt's Avatar
I have the exact same problem, in searching the forums...several people mention that the windshield cowl is loose....try taping it off in different areas and see if it kills the noise.
good luck
Ike
Old 12-05-2012, 02:15 PM
SUB VETTE
SUBVETTE
Support Corvetteforum!
SUB VETTE's Avatar
Frequently reported problem with the plastic cowl piece at the bottom of the windshield vibrating in the wind. I think there is a TSB out to fix it. Check with the dealer.
Old 12-05-2012, 04:51 PM
CO Lightfoot
CO Lightfoot's Avatar
http://forums.corvetteforum.com/c6-c...ing-noise.html
Old 12-05-2012, 04:52 PM
N2TU
N2TU's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18
Yes, I had it and the dealer fixed the flapping plastic cowling....
Old 12-05-2012, 05:53 PM
TonyFaub
TonyFaub's Avatar
I heard they were working on a permanent solution to the cowl problem. Should be announced on January 13th.
Old 12-05-2012, 06:54 PM
ButWhatDoIKnow
ButWhatDoIKnow's Avatar
good luck
Ike
...or the hampsters running the on-star.
To new car Noise in dash
Quick Reply: new car Noise in dash
