New Seats vs. Old Seats
Have a 2011 GS vert and thinking about going to the new seats.
For those Forum members which have moved up, either thru a seat conversion or new car upgrade, are the seats really that much better?
And, is a $2,000 upgrade worth it?
I've done the swap myself. I went from the 2010 seats to the 2012 4LT seats with Alcantera centers.
I did the complete swap myself so it only cast me about $1300 and I am happy because I got the look I wanted and the Alcantera centers do hold me in place better than the smooth leather did.
I did it solely for the new look and to get the Alcantera and 2-tone seats.
If you are talking about just how the seats feel, no, it's not worth the money you would have to spend. The seats are pretty much the same as far as the bottom is concerned. The seat back has a little different feel to it, when you are leaning back, because of the shoulder area but you might not even notice it.
Hope that helps.
Hope that helps.
Unless the seats are worn out/damaged or its a cosmetic upgrade I wouldnt spend the money. I notice little difference between my old '08 and this '12 as far as the seats go.
I had mine done in all Italian Leather, back sides, etc. An unexpected advantage of the Italian leather is that you do not slide around as you do on stock leather. I modified the vette flags. I really like how they turned out.
Thanks guys. Was looking mainly for the change in comfort and the consensus is that it is not worth the $$.
Appreciate the feedback.
I followed ncvette_1FUNRIDE advice except I had a professional do the swap for me. No way I was going to attempt that myself. And you are correct, it was about $2K.
In my case, my car was well used and I needed the bottom foam replaced badly. I took it to the interior guy he pointed out all the wear and tears I never noticed - and after that it ate at me and I knew I had to replace the leather. So upgrading was a no brainer.
But I have to disagree that there was a major difference in the feel of the backs. I don't think that my old back foam was that worn out to account for the difference. In my case it was night and day and made the cost well worth it.
Every once in a great while you do see people that buy brand new cars and send their seats out for upgrade and so they try to sell their brand new seats. Last one I saw the guy wanted a ton for it and it would have been cheaper to just do the upgrade. I guess if you are patient you might be able to find a deal.
I found a local upholstery shop and had them re-do the stock 2010 C61LT Coupe seats with black perforated suede center sections. Felt a little softer under butt, but sure did stop the sliding laterally in the stock seats. Looks nice too. Cost was $800.00. It's another option for you.
The difference is mostly GM marketing hype...minimal in reality. As was said above, a little suede or ultrasuede can make a greater difference in support.
For $2K you are getting is a fresher looking version of the prior seat, with partial leather and a lot of vinyl, installed. There is little difference in support or durability. It is a nice look, though, and the look alone might be worth $2K to you. You can get the same look in real leather, better support, and better quality from Apsis or other sources, but it will cost you even more to do it right.
If your seats are in OK condition now, consider waiting for the C7 and see what kind of seating options that brings, if any, that might make more of difference and work in a C6.
Remember, if you go to sell the car soon, you aren't likely to get any kind of money for any of this sufficient to justify the expense.
For 2 grand you could probably retro fit some nice C4 sport seats!!That was the best generation for Vette seats that I know of. The look of the upgrade over oem cheap stuff and the feel of better material is definitely worth something!
I have the 2011 seats and had the opportunity to drive a couple different cars with the newer seats at Spring Mountain. I could not tell any difference except for a car with the alcantera insert. The alcantera inserts help keep you in position when on the track better than the slick leather.
DIY upgraded '11 1LT seats to the alcantara and the difference in comfort and stability (no sliding around) was worth the $1300, IMO. Embroidery and contrasting stitching was an added bonus in the looks dept as well.
Went from 09 Z06 to 2012 Z06 wanted a z07 and found and 11 but liked my seats to much to trade down.
z51vett
Just my 2 cents worth
z51vett
If you are sliding around in your seats chances are you are wearing polyester pants or used the wrong product to clean your leather seats.
If your seats are in OK condition now, consider waiting for the C7 and see what kind of seating options that brings, if any, that might make more of difference and work in a C6. Remember, if you go to sell the car soon, you aren't likely to get any kind of money for any of this sufficient to justify the expense.
Received 2,049 Likes
St. Jude Donor '13
I had no problem getting in or out. The only down side may be that they seem hot and you may sweat more in the alcantara.
